Old 11-07-2015, 02:18 AM   #1
RV Vagabond Jerry
Jerry Dixon's Avatar
Lightbulb Wind turbine to use while driving
Has anyone heard of a wind turbine to charge batteries, that you can use while driving?
Jerry Dixon is offline   Reply With Quote
Old 11-07-2015, 07:41 AM   #2
Flybob's Avatar
Most wind turbines are not designed to operate at highway driving speeds. The higher end ones actually feather blades when wind exceeds a certain speed.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 11-07-2015, 07:50 AM   #3
The_Rhino's Avatar
Isn't this the job or your TV's/MH's alternator?
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2017-31
2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
Old 11-07-2015, 08:26 AM   #4
Evereddie's Avatar
Exactly. There is no free power. If you found a suitable wind turbine it would create air drag that makes the power it creates less efficient than using the alternator. If you need better charging, get a bigger alternator and increase the size of your wiring.
Evereddie is offline   Reply With Quote
Old 11-07-2015, 08:36 AM   #5
MarsMan's Avatar
Never on a moving MH. I have seen some systems for when people boondock and have solar too. Looked at this setup however was cost prohibitive... plus could not leave it hooked up while underway. I see Sail boats with them all the time to top off the batts. However they are not mving at highway speeds. I would rely on my alternator to charge/maintain batteries while underway
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
MarsMan is offline   Reply With Quote
Old 11-07-2015, 08:59 AM   #6
northstar1960's Avatar
THERE are lots of marine turbines that can easily be set up at camp .While driving the TV alt should be keeping the batteries charged
northstar1960 is offline   Reply With Quote
