Old 09-14-2016, 09:13 AM
Question Window question on Grey Wolf 26DBH
Hi,
We have a 2016 Grey Wolf 26DBH trailer. We are wondering if the emergency window in the bedroom can be opened for ventilation use or is it for an emergency exit only? Since it has a screen on it we thought we could just open it but not sure how to do that or if we even can.
Thanks for your help!
mjingman is offline
Old 09-14-2016, 09:55 AM
SeaDog's Avatar
Myself I would not use it for ventilation it is designed when opened to come out of the opening so you can exit, you run the risk of it doing just that when using it for ventilation.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
SeaDog is offline
Old 09-15-2016, 11:45 PM
I actually do use ours for ventilation. It's not very easy as the seal does stick quite well to the Window frame but it will not just fall out of the upper hinge.
Tim_n_Jenn is offline
Old 09-19-2016, 12:45 AM
I use it all the time as it's the only window in the bedroom. Never had a problem with it. I also used it on my 17BH without and problems.
marshbrian68 is offline
grey wolf
» California Campgrounds
