Old 02-21-2011, 03:15 AM   #1
Angry windsong fridge
yellow check light keeps coming on . been in the same park 1 month. no problems with 50 amp service. I can hear contact "click" about 1 min. after resetting on/off switch and ck. lite reappears. any hints about cause or solution? Propane is turned off. on elect. only all the time.
any help???
thanks
cdrifter is offline   Reply With Quote
Old 02-21-2011, 07:03 AM   #2
Herk7769's Avatar
any help???
thanks
OK, my guess.
You are hooked up to 30 amp (or 20 amp) service with a 50 amp camper.
The leg with the fridge on it is not getting power because that leg is not getting power the one that is plugged in (50 amp service has two legs).
Did you make your own pigtail adapter? The correct leg must be the one to get power when you adapt to 30 or 20 amp.
Since it is not getting AC; the fridge is trying to cool on propane but you turned it off. Thus the check light goes on when it tries to start but can't.
How am I doing?
HAM CALLSIGN - KC3FFW
Old 02-21-2011, 07:35 AM   #3
What brand of refer?
Old 02-21-2011, 07:40 AM   #4
Herk7769's Avatar
There could also be a GFCI that the fridge is plugged into that has popped. Open the outside cover and see it it needs to be reset.
Old 02-21-2011, 07:49 AM   #5
Head Rambler
Those fridges also require 12v supply for the control baord. There have been several instances where the connnections on the control board have slightly corroded and caused the problems you're experiencing. Just unplugging/replugging them a few times solves it for a while. If that does fix it then a good cleaning is in order along with some dielectric grease.
Gotta go campin!
Old 02-21-2011, 07:55 AM   #6
Herk7769's Avatar
He did say that the fridge tries to fire before the check light comes on.
That typically means 12volts is available but propane is not. The wires to the propane valve could be bad though. That is a thought...
Old 02-21-2011, 09:27 AM   #7
KyDan's Avatar
Lou, original post says they've been there a month
ON 50 amp service and the refer is set on AC not gas.
Could still be low battery or missing 120v ac to the refer.
These are easy to check with a meter.
As you said, I suggest opening the outside cover
on the refer and checking the 120v ac outlet for
power and also check the 12v supply that it's 12v dc or more.
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 02-21-2011, 10:18 AM   #8
Herk7769's Avatar
Now see. I read that differently initially; but now that you say it again I get it.
I still say no AC at the fridge is the problem. The WHY is the answer.
I still lean toward GFCI trip.
Old 02-21-2011, 02:05 PM   #9
Windsong Fridge
Thanks for all of the suggestions and trouble-shooting. It seems after putting meter on recep. I have a netrual wire malfunction. plugged in extension cord and refer working as it should.Need to replace receptical now.
Thanks for all the feedback from everyone!!!!!
Its great to have this forum to bounce problems around and get great responses.
Gary
Old 02-21-2011, 02:40 PM   #10
Herk7769's Avatar
Our pleasure
