Old 01-17-2015, 02:58 PM   #1
Oakman's Avatar
Winter Damage
OH NO BOO HOO! Cold weather damage to my Silverback. I guess the expansion and contraction of the metal in the bedroom slideout was just too much for the little piece of plastic trim. I am surprised at how large the gap in the plastic is. I guess Iíll be going to the Goshen rally to have it fixed.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 01-17-2015, 03:19 PM   #2
Campfire Master
It almost looks like the bottom rail has moved down, causing the trim to split. Probably just the freeze, thaw thing, but worthwhile to check out.
John
AVid is offline   Reply With Quote
Old 01-17-2015, 03:58 PM   #3
Attachment 68509
Bob I don't think that's from freeze/thaw, it's a piece of plastic which I believe wasn't drilled right or perhaps not drilled at all but installed at the factory using the screw as the drill. It appears to me as a stress crack because it is right at the screw hole as is the crack at the screw above. Also the screw may have been driven down too tightly initially? You see a lot of these type of cracks at the screw holes on the wheel well covers on many older trailers. Good luck with the repair.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 01-18-2015, 07:16 AM   #4
Oakman's Avatar
I think you're right. The screws were driven down too tightly but I didn't think this would happen though. Fortunately the piece is just cosmetic so I'll wait til Goshen to have it fixed.
Bob and Joyce
ATU Local 788
Old 01-18-2015, 08:34 AM   #5
rattleNsmoke's Avatar
Hi Oakman. The problem is that you might lose that corner trim piece or a chunk of it traveling down the road. I'd snap a pic, send it to FR and see if they'll 'good will' you another. If they didn't, the cost is prolly minimal. This way you won't have to go all summer with that fugly corner trim.
rattleNsmoke is offline   Reply With Quote
Old 01-18-2015, 09:00 AM   #6
mark0224's Avatar
Last winter my linoleum floor split from the cold looked like they had it in so tight that the cold split it from one corner to another in our bathroom. It sucks but only thing you can do is replace it.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
Old 01-18-2015, 09:25 AM   #7
caper's Avatar
Did you leave the 4 corner jacks down? Last year several TT in the CG had damaged flooring and all left the support jacks down. I always have mine up during the winter. This allows the trailer to flex when the frost heaves.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-18-2015, 09:42 AM   #8
First thought that came to my mind is what about al those seasonal trailers that are permanently left on RV sites all year long? There's thousands of them out there. The stabilizers are mounted to the frame not the side walls. Just a thought.
BTW, since there's two cracks at the screw heads they probably tightened them too much originally. Nothing major.....
billb800si is offline   Reply With Quote
Old 01-18-2015, 09:56 AM   #9
caper's Avatar
My comments where about the flooring splitting not the plastic trim.
Terry and Janet
2007 Ford F150
Old 01-23-2015, 09:05 AM   #10
mark0224's Avatar
I've always left them down very windy here , a friend had theirs up and their trailer flipped on its side. Guess I will take the split over the flip.
winter
