Old 10-17-2013, 11:35 PM   #1
Winter living cost effective skirting .
Hey fellow campers , I know I'm not first or last to try this but here it goes. I considered using bails of straw only to be worried about rot and mice and to buy lumber and build walls is very time consuming ( I work oil patch so I haven't got lots of time .) . So I picked up free 4 ft pallets , chopped them in half and screwed them together with some free
old pliť wood . What do you guys think?
Gafner is offline   Reply With Quote
Old 10-17-2013, 11:57 PM   #2
Great job. What did you wrap it with? Do you have a heat source under the unit?
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 10-18-2013, 12:02 AM   #3
Two layers of vapor barrier ( plastics poly sheet). And for the heat source I was thinking a small electric heater dead Center sitting on cement blocks
Old 10-18-2013, 12:12 AM   #4
What did you do with your sewer and water connections? Where are you? N Dakota?
I'm just curious, I live in Florida and admire your ingenuity. I don't have any experience with what you are up against...
2016 Siverback 33IK
Old 10-18-2013, 12:47 AM   #5
To start with my work I'm gone 2-3weeks at a time so it's hard to justify renting a house I'll never See. Currently I only shower in the unit (other I do at the work shop ) . I'm going to buildin a connection box at the back for sewer (insulated). I have a plastic tank that sits in box of truck when I need to haul the shower water away. And fresh water I have another tank I haul in with. So the lot I'm sitting on is a industrial lot fenced and rented to me privately, it has electrical. I live up in central Alberta near Calgary, Canada . I plan on building a shop in the spring with living quarters , but until then I'm in the RV
Old 10-18-2013, 09:37 AM   #6
I am from Florida but I know how cold it gets in Calgary. The company I worked for in the early 80's installed the worlds first fiber optic trunking system from Calgary to a microwave facility in Cheadle. I was there in early January to work on the system. I can see why we have so many Canadians in Florida at that time of year
I know there are other members on this site who have experience with your situation and hopefully they will chime in.
Good luck and keep warm.
2016 Siverback 33IK
Old 10-19-2013, 07:50 AM   #7
mduff's Avatar
Originally Posted by Gafner View Post
Hey fellow campers , I know I'm not first or last to try this but here it goes. I considered using bails of straw only to be worried about rot and mice and to buy lumber and build walls is very time consuming ( I work oil patch so I haven't got lots of time .) . So I picked up free 4 ft pallets , chopped them in half and screwed them together with some free old pliť wood . What do you guys think?
Have you considered some rigid styrofoam to provide some insulation? Suspect that your heater will have a job to keep things warm otherwise. Too late regarding the tape, however suspect you'll need some effort to get the glue off your TT come spring.
Mike and Brenda
TV - 2013 Silverado 1500, 5.3L
TT - 2012 Wildwood 26 TBSS
mduff is offline   Reply With Quote
