Old 10-15-2015, 09:33 AM   #1
Retired
MainelyUS's Avatar
Winter Storage away from home
Well...we had a "killing" frost this morning and unfortunately we begin our day with the discussion of beginning the process if winterizing our Windjammer for the first time. Our yard is too small to keep the TT at home so we are bringing it to the dealer for winter storage. I am more concerned with what to leave with the TT than the winterizing process...all food, clothing, etc will be removed but what about the LP tanks, battery, spare tire, etc. I'm I being to paranoid
Thanks for the inputs.
Happy Trails to all you snow birds
2017 Columbus 340RK
GMC Sierra 3500HD Z71 6.6L Duramax/Allison
MainelyUS is online now   Reply With Quote
Old 10-15-2015, 10:10 AM   #2
Fulltime family RVer
IMO, go drive the dealer's lot and see what others are doing. You'll get many varied answers and it really comes down to "it depends". It depends on the area and the likelihood of theft or vandalism.
I always stored my camper at a storage lot (not enough room + HOA restrictions) and never removed anything. In fact, most of the campers there didn't lock the tongue/hitch or anything.
ependydad is online now   Reply With Quote
Old 10-15-2015, 10:11 AM   #3
Make sure your RV is covered Ins,wise OFF Site! Most Dealers/Storage areas Dont Cover LOSS/Damage! Youroo!!
Old 10-15-2015, 10:14 AM   #4
Boss Ox & Drovergirl
oxcamper's Avatar
Other than taking everything edible, chewable, or rottable out of the camper (which you're already doing) the only thing I would consider is disconnecting the battery and bringing it indoors (I do this with my motorcycle for winter storage). Makes it last longer and you can put it on a trickle charger in March to get ready for the season.
LP tanks will be OK.
If you're worried about theft and damage, find out what the dealer's insurance policy covers on units stored or if your policy would be in effect.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 10-15-2015, 12:34 PM   #5
What To Leave Over Winter
The LP tanks can stay but definitely bring the battery in. If it goes dead over the winter, it stands a ggod chance of freezing and cracking, then you have sulphuric acid all over the place. I wouldn't leave it on charge in the house, even a trickle charge. I've seen many a battery go dry from overcharging. Just let it sit and connect it up every month for a few hours, just to keep it happy.
RussPastuch is offline   Reply With Quote
Old 10-15-2015, 12:51 PM   #6
oxcamper's Avatar
Agreed. I don't put mine on until about a month before I plan to reinstall it.
Old 10-15-2015, 07:58 PM   #7
Dabmeb's Avatar
We always leave everything in the trailer except food and liquids.
I trust our storage lots very much. We were away camping the first week,of October and received a call from the lot. They had a security breach and called to make sure our trailer was ok as it was not in the lot. That is great customer service in my books.
Dabmeb is offline   Reply With Quote
Old 10-15-2015, 08:29 PM   #8
Does anybody cover their rig for the winter? My first year I stored my FW indoors. This year I am leaving it at a seasonal campground for the winter. Should I cover it?
2015 GMC Denali 3500 4X4 Duramax
2015 Cedar Creek 36CKTS (flooded 2-20-18)
2019 Cedar Creek 36CK2 (picked up 5-1-18)
grumpyoldman is offline   Reply With Quote
Old 10-16-2015, 07:43 AM   #9
chipmy's Avatar
I'd say go with your instincts. PLAY IT SAFE!
I will take my battery off and put it on trickle charger in the heated garage for with winter season and I'll my water level 2 x a year (once for winter and again in spring filling with distilled water as necessary) . All food items will be removed and the I thoroughly clean my unit. Obviously, I run RV antifreeze through the water lines and pour some down each drain. I place spacer in the refridge/freezer doors so it wont be shut up all winter. Where I store mine is inside a locked building so I leave propane tanks and spare tire intact. With everything is locked up tight.
My friend if your questioning it then I would go with your gut instinct. Removing the spare and propane tanks might be thought of as being paranoid but if your at all questioning I'd take them off.
We obviously live in a very different world today than even a few years ago unfortunately.
I hope this helps you in your decision making process.
chipmy is offline   Reply With Quote
Old 10-16-2015, 08:13 AM   #10
oxcamper's Avatar
Yes we cover ours. We too leave it in a seasonal campground.
I believe it helps keep the roof and walls protected from UV, ice & snow buildup, and debris. Use a high quality RV cover that's vented, "blue taprs" are cheap and not breathable.
When you figure the cost of your RV, the $500 or so for a good cover is a cheap garage.
storage, winter
