Old 11-02-2011, 02:05 PM   #41
TURBS's Avatar
Exclamation
Originally Posted by CliffP View Post
You should really pull it back out of the garage! If water freezes in your water filter it could crack the housing and you'd have to replace the whole thing, not just the filter. The water heater should also be drained. Take the access panel off the outside of the camper. There should either be a drain plug (see pic) or I think some models have a heating element to remove to drain tank.
Even if you left water filter in the canister and ran antifreeze through it won't freeze.
My father inlaw did this all the time bless his heart.
His motto was why mess with it twice. This happened every year for 20 years.
And his never froze.
Me on the other hand I take it out since I can just reach into the basement and do it.
I moved it from factory location to just inside my basement door.
Old 11-04-2011, 06:26 PM   #42
Just did first winterization.. Emptied fresh tank. Blew out city connection w/ low point caps off.. Drained WH.. (Bypassed) then pumped in AF... An unexpected 29 degree night before winterization burst the outside shower valve.. (I have replacement on order)
Q1 - Should I wait till spring to repplcae the OS shower valve?
Q2 - What about the black & gray tanks? Leave dump valves open? What should I put in tanks?
FR Surveyor SV302 (2008)
2007 Toyota Tundra w/ tow pkg
About 25 enjoyable nights in 2011!!
rlray42 is offline   Reply With Quote
