Old 09-12-2016, 01:40 PM   #11
Flybob's Avatar
Air and antifreeze ( air will get the city water line )
Don't forget spray wands or outside shower.
Store on tires.
Cover
Essential oil of peppermint on cotton balls in old mug for mice.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-12-2016, 02:03 PM   #12
Originally Posted by kcmusa View Post
Looks close, is there some clearance up there.
It is close.
About 2 inches between the top of my MaxxAir cover (my highest point) and the overhang.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
Nights Camped: '15 = 22'16 = 46
Old 09-12-2016, 02:06 PM   #13
BandJCarm's Avatar
Winterizing.........geez.
We won't get a frost until mid November.
This is one big planet.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 09-12-2016, 02:12 PM   #14
We are getting into the season where an unexpected overnight freeze can happen without warning. Even though I'm not ready to fully winterize, I have started blowing out the water lines between trips just in case. I will fully winterize with anti freeze about a month from now.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 09-13-2016, 07:53 AM   #15
ToniandSal's Avatar
Interesting methods mentioned above. I'm curious though, how does one collect the coyote urine to spray on the tires?
ToniandSal is offline   Reply With Quote
Old 09-13-2016, 08:17 AM   #16
Chief tinkerer
Gidyupgo's Avatar
Winterization time approaching
Name:   ImageUploadedByForest River Forums1473772656.110284.jpg
Your question made me spew coffee. More than you ever wanted to know here. Predatorpee.com
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 09-13-2016, 08:32 AM   #17
Very carefully.
Old 09-13-2016, 08:53 AM   #18
Pretend your a tree and wait.
Old 09-13-2016, 09:27 AM   #19
ToniandSal's Avatar
Ha ha ha !
Old 09-13-2016, 10:04 AM   #20
BlackJeep22's Avatar
Compressed air?
I just sanitized mine a couple of days ago, and was curious to see if I could blow any water out after completely draining.
I ran the bleach water through the faucets, so drained the Grey tanks and then pulled the "low point drain valves". I let it drain all night.
The next morning, after closing all the faucets and Grey tank valves, I hooked up a blow out adapter to my tank fill opening. Being cautious, I only ran about 45 psi through the lines, but would say it only pushed about a tablespoon of water out the low point drains. Not sure if that was because I needed more pressure or just a good design on the coach. As a result, not sure I'll use antifreeze in the lines, maybe just down the drains.
Thanks, Steve & Deb
2016 Coachman Concord 300DS
-Safe-T-Plus | Garmin RV 660 MLT
2008 Jeep Sahara
-Blue Ox base plate | Ready Brute Elite
BlackJeep22 is online now   Reply With Quote
winter
