Old 11-14-2014, 07:44 PM   #1
winterize
getting my tt winterized tues, until then the night lows will just about reach freezing buy nothing consistent through next few days, will i b ok?
Jfmf527 is offline   Reply With Quote
Old 11-14-2014, 09:51 PM   #2
Dave_Monica's Avatar
Maintain some heat in the camper by electric heater or furnace just to be safe. Turn on 12V tank heaters if you have them.
Dave
Old 11-14-2014, 11:45 PM   #3
1l243's Avatar
If your rig is newer you probably have Pex tubing for plumbing. It holds up to freezing very well. You have to worry about P traps at sinks, shower. to be safe you can buy a gallon of RV antifreez and dump a little down the sinks and shower.
It usually takes a few days below freezing for things to setup. Put a glass of water outside and see if it freezes. When it starts to freeze then you got to get the tt done.
You can also set the furnace to come on at 50 degrees or whatever the lowest setting is. Open up all the lower cabinets to allow heat to the plumbing and turn on any tank heaters...
1l243 is offline   Reply With Quote
Old 11-15-2014, 12:21 PM   #4
If you have power, strategically placed light bulb will add some heat. Used this for years when had my 28ft cruiser in the water in Jacksonville, FL. 1, higher watt bulb, offers plenty of offset heat. I used 2 in engine compartment down to low 20's. Never an issue. When in New Jersey, pulled boat and drained😜
Of course on an RV, depends on where it is and for how long before winterizing.
ADVICE: get the small electric air pump and fittings required to blow out the system AND buy the inexpensive kit for water pump to pull anti freeze and push it through the system. Winterizing is an ez process. Just follow ALL processes to avoid issues. Being in GA, I use our RV and re winterize 2 to 4 times a season. In winter, I never travel without 3 gallons of rv anti freeze. Never know when something might cause us to lv the rv for a period of time. Even when camping in central FL.
SilverbackMel is offline   Reply With Quote
winter, winterize
