Old 06-15-2015, 04:05 PM   #1
TF-Kevin's Avatar
Winterized water valve
I had to replace the winterized valve from my hot water tank, it's the plastic valve meant for the plex pipe , but I noticed after I installed it the arrow on it was pointed the wrong way, will I have a problem if I leave it, or should I change it around,
Kevin
Kevin & Debbie and our little dog Emma
2004 F-150 Lariat 4X4 Ext Cab 5.4
2010 Flagstaff Shamrock Hybrid 19
TF-Kevin is offline   Reply With Quote
Old 06-15-2015, 04:09 PM   #2
Ford Idaho's Avatar
The one in the middle?
I doubt it will be a problem, water can not see the arrow....
Old 06-15-2015, 04:12 PM   #3
TF-Kevin's Avatar
The top one , the out going hot water line
Old 06-15-2015, 04:53 PM   #4
Ford Idaho's Avatar
If the valve has a check ball inside that could be a problem.
Old 06-16-2015, 07:17 PM   #5
TF-Kevin's Avatar
its just a standard valve, open and close, no check valve at all
Old 06-16-2015, 07:21 PM   #6
Ford Idaho's Avatar
Cool, should not even be an issue, camp happy...
water, winter, winterize
