11-22-2016, 09:45 AM
Winterizing
How many of you blow out your lines before putting antifreeze into them? Won't the antifreeze push the water out?
11-22-2016, 09:54 AM
I have never used compressed air to blow out the lines. IMO it does an incomplete job. There can still be water in your pump for example. It doesn't take much water to break a pump. With anti-freeze, there is no doubt. And you should have it in your traps anyway. It's super-simple and takes maybe 3 gallons. Complete protection. Just don't put the anti-freeze in your fresh water tank. Most/many units have a way to switch to a tube to draw in the anti-freeze. Remember to drain your water heater and to bypass it. If you have water filters, take them out of the canisters first.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
11-22-2016, 09:59 AM
The original poster was not implying just blowing out the lines...he asked how many people blow out the lines before doing the antifreeze process.
I do blow the lines out first, is it necessary...no...but in my head it dilutes the antifreeze less and I pretty much see pink stuff coming thru immediately when I turn a tap on after having blown out the lines.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
11-22-2016, 10:14 AM
Insert witty title here
I give my lines a pre-blow before pumping in the antifreeze. Like WFD said, it keeps the antifreeze from getting diluted from water left over in the lines.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
11-22-2016, 11:16 AM
I open the three low point drains valves and than blow out the lines with compress air. I than add the pink RV antifreeze to the lines, by passing the hot water and fresh water tanks. Since my trailer has the washer and dry prep, I make sure that those lines are also blown out and pink stuff goes through these lines.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
11-22-2016, 12:13 PM
I drain my lines at the low point drains and also the water heater drain, and bypass the water heater.. I then close the drains and pump antifreeze through the lines.
I suspect using air and then followup with antifreeze would do almost the same.
I would not use antifreeze to push water, would require to much antifreeze to ensure its not diluted enough to offer the protection I need. (-10 to-20 deg F)
Doing just a drain or air could allow small pockets of water to pool. Depending on where the water pools, when it freezes, it will expand and could damage pipes, fixtures, pumps, valves, etc.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
11-22-2016, 01:30 PM
Using air to blow out the lines prior to drawing in antifreeze allows you to use less antifreeze.
Simply because as soon as the pink stuff starts to come out the faucet (or anywhere else) it is almost pure antifreeze, not a diluted mixture of water and antifreeze.
Edit:
I say 'almost pure' because no one has shown me proof that blowing out the lines removes 100% of all water.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=86
11-22-2016, 02:20 PM
I blow out my lines, no antifreeze, cannot stand the taste that lingers. 15 years of hard freeze no issues
Stefan
2014 - Sabre 36 QBOK
Nights camped 2014 - 38
Nights camped 2015 - 46
Nights camped 2016 - 43
Nights camped 2017 - 2
11-22-2016, 02:48 PM
Same here.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
11-22-2016, 05:33 PM
Never blown out a line. We get long stretches of minus 30 and have never had a problem. If you pump antifreeze till pink comes out of all faucets and toilet why blow out lines?
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
11-22-2016, 05:39 PM
Because the water in the lines will dilute the antifreeze you pump in. If all the water is blown out ahead of time, when you see antifreeze come out, its full strength.
11-22-2016, 07:08 PM
As I said previously in this thread, you will use less antifreeze. It won't be diluted.
You don't have to blow out the lines as long as you don't mind pumping enough antifreeze to be sure what comes out is ALL pink and isn't diluted.
11-22-2016, 07:33 PM
Getting rid of as much water as possible is why I blow out the lines. Then add the pink stuff. Takes a few extra minutes.
11-22-2016, 07:44 PM
I too usually blow out the lines before pumping the antifreeze............ For me usually takes less than 2 gallons for the lines
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
11-22-2016, 08:20 PM
After blowing out, 1.5 gallons did all lines and plenty in the traps. YMMV.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
11-22-2016, 08:58 PM
Same with me. I was amazed as to how much water remained after draining.
2016 Coachmen Freedom Express Liberty Edition 292BHDS
11-23-2016, 02:23 PM
Add me in for those amazed at how much water remains in the lines with just a simple draining, especially the toilet. For the time it takes to blow out the lines with my little compressor, its well worth the extra effort and half hour or so after everything is considered. In my Georgetown I will use exactly one gallon of pink stuff then including pouring some down the traps.
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
