Old 10-07-2013, 09:52 PM   #1
Winterizing / Attachment To Air Compressor To Blowing Out Water Lines
I have a question about the "right tools for the job" when blowing out water lines to winterize.
I use the Camco plastic blow out plug:
Name:	camco plastic blow out plug.jpg
And then I try to use one of these attachments that came with the air compressor. However, none of them fit just quite right. The black one is a little too big (so some of the compressor air escapes around the edges). The blue one is pretty close but I need to hold it right on top of the hole in the Camco plug (so again, some of the compressor air is escaping around the edges).
Name:	air compressor attachments.jpg
Is there some other attachment to the air compressor that I should be using?
Thanks!
paulmlac is offline   Reply With Quote
Old 10-07-2013, 09:58 PM   #2
wowzer's Avatar
You should have purchased one that has a built in air stem in it. Then you can clip the air nozzle from the compressor to that.
Jim and Sherri Brown
2013 Silverado 2500 6.6 DuraMax
2012 Sabre 34REQS6
wowzer is online now   Reply With Quote
Old 10-07-2013, 10:01 PM   #3
Ford Idaho's Avatar
Camco RV Winterization Blow Out Plug Brass 50PSI Max Z | eBay
Ball Tire Inflator Air Chuck Clip Type Right Angle DIY Automotive Brass 1 4" NPT | eBay
Old 10-07-2013, 10:06 PM   #4
wowzer's Avatar
X2 Ford Idaho....you beat me to it. Just be sure to NOT go over 30 psi when blowing out lines.
2012 Sabre 34REQS6
Old 10-07-2013, 10:07 PM   #5
OP here again: A-ha. So it sounds like I got an el-cheapo blow out plug. I should have gotten a brass one that has a stem in it almost like a tire. Then I could use the attachment on the air compressor that I use to inflate tires. Please advise if that's NOT right. Thanks!
Old 10-07-2013, 10:10 PM   #6
Ford Idaho's Avatar
You got it!
Old 10-07-2013, 10:36 PM   #7
Anacortesians
I got an el-cheapo adapter (about $1.89) from Wally World's RV section that had a Schrader tire valve-size on one side and a male hose-thread on the other. I use the tire inflation thingy on the compressor hose and it fits the Schrader-like connection just fine.
With the compressor tank at 120 psi and the output regulator set for 30 or so, I can blow most of my system out without the compressor coming on again. Of course, the water heater is out of the circuit with the bypass valve. A cup full of the pink stuff in the sink drains and the shower drain and we're set.
Three winters so far and no problems. Bear in mind that a really nasty freeze here is down to around 25F and doesn't last more than two nights. Daytime highs are rarely below about 36. A harsh climate it's definitely not, which is one reason we live here.
Frank and Eileen
No longer RVers or FR owners
Old 10-08-2013, 05:45 AM   #8
fonzie's Avatar
Or you can use a small piece of tygon tubing between blow plug and your red air adapter.
Fonzie
Old 10-08-2013, 06:17 AM   #9
leencharlotte's Avatar
http://www.amazon.com/gp/aw/d/B00BVU...110_SY165_QL70
This is the one i have used. It actually has the quick connector for the air compressor rather than a tire valve. I also purchased an inline filter to keep any oil, dirt, etc from the compressor out and attach that to my 90 deg elbow so it hangs down not out.
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
Old 10-08-2013, 07:21 AM   #10
KyDan's Avatar
I use the same as the photo below except all I have is a brass water hose
fitting that's screwed directly to a male air quick connect.
Like the photo with the center stuff missing....
Since my water pressure regulator is typically set at 40 I don't
worry about air pressure more than that.
I usually have a faucet open at all times during the blow out so I don't
even use an air regulator. Just plug on the air hose and stand back.
That open water heater drain has sprayed me too many times!
Peace!
Dan & Rita D
Blue Ox WD hitch
water, winter, winterize
