Originally Posted by TNYHWZ
Some issues with winterizing ..
Drained and bypassed hot water heater
-Drained low end lines
-Removed water filter and place empty water bottle in take up volume.
-Blew lines out with compressed air
- Turned switch to "winterize" at bottom of shower
-Placed tube in antifreeze bottle and switched water pump on
-Very slow uptake of AF
-Opened faucets and no pressure for quite a while
-finally pressure out of cold water side--ran until AF came out
=No pressure on HW side
-removed drain plug from HW tank to check and was under pressure and had water wit AF mixed in. How could this be if HW tank was bypassed?
How do I get pressure on HW side to remove water?
Would appreciate any advice---Thanks.
If the HW tank was indeed bypassed-- it wouldn't have had any antifreeze. Think you probably missed the bypass valve?
The best way to winterize the lines is to open one faucet at a time, closing it when the faucet has deep pink color. Same process for all faucets! Don't open the faucets again until you dewinterize.
