Originally Posted by C.Lee
Spoke with a local dealer who suggested I just turn on the furnace to its lowest setting for days we may get below freezing which is not often. He felt winterizing was overkill for our area. With that said, I will need to get a generator to power the furnace. Does running the furnace require the same amount of watts as the AC? Been looking at getting a generator/inverter but not the big ones since I have no intention of boon docking.
We live in the DFW area so "winterizing" isn't paramount for us either, that said it's 24 degrees outside right now. So we went to plan B on Monday.
Plan A is to use a compressor and blow all of the lines out with this...
https://www.amazon.com/Camco-Brass-C...interizing+kit
We set the regulator on the compressor to 60 psi and take our sweet time. I'm very thorough. We don't use the trailer for a few months in the fall usually so I do it then.
Plan B is a couple of gallons of the pink RV antifreeze when we get a hard freeze. Remember the traps, fridge, black tank flush and outside shower.
Yeah I know a lot of folks will say it's belt and suspenders but I've never had an issue either.
