Originally Posted by ca443
I really hate to ask this as I am sure someone, sometime asked before. I did watch some videos, and read some articles but couldn't find an answer.
I am looking to winterize my new 27DBK Wildwood. I found my water pump under the fridge, and it has one line in and one line out, so will be buying a Camco Pump Converter, or making my own with a longer hose.
I also found access to my hot water heater in the closet. However, this is where my question begins. My hot water heater has two valves. One on the hot line and one on the cold line. There is no bypass hose between the two hoses. If I just shut both valves, this will keep me from filling my hot water heater but does it still winterizes those hoses? Or do I need to buy a bypass kit that will allow me to have the hose that connects the two lines so that I can run antifreeze throughout them?
Thanks in advance.
Firstly, NO you do not need a bypass kit if your 2 valve setup is similar to this one in this picture.
To put the system in bypass mode, turn the 2 valves "parallel" with the center Blue water line. These are 2 way valves and once turned they create a bypass for winterizing your system. My first time as well having this type of bypass, so was a learning curve for me also. My winterization is complete....they worked great!
If you are in doubt, as I was at first, with using this 2 valve setup, I left the hot water drain anode rod out while I was winterizing with AF and watched to see if I had a flow of AF coming out of the water heater. No AF, so it was a successful bypass. Winterization complete.
*please excuse the sideways pic.
