Do as you've done before, that's what I do. Drain and blow lines, then pump anti freeze through. Run water through door then leave pump on for a few hours until 2-3 cycles of ice have run through the ice maker. All is good! If your fridge has a filter that has to be in place for water to flow, they will usually remove he antifreeze coloring, mine did.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
