Old 11-17-2016, 05:04 PM   #11
HeavyPuller's Avatar
Uh, not my job..
HeavyPuller is offline   Reply With Quote
Old 11-17-2016, 08:36 PM   #12
If you have pulled the battery, you can take jumper cables and your vehicle in lieu of lugging battery back. Just use extreme caution that the positive clamp does not contact frame. Clamp the battery terminal wire to the plastic battery box to prevent problems. 15 mins lost for a whole winter of restful sleep small price to pay.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 11-18-2016, 05:39 PM   #13
My advice... re-pressurize the system (your choice as to how you do that) and pump some antifreeze OUT through the outside shower.
I say your choice as to how you re-pressurize.
If your rig is stored somewhere inconvenient or you've possibly removed the battery, or the antifreeze connection is a PITA to get to... I wouldn't see any reason you couldn't hook a short piece of garden hose to the city water connection, fill the hose with antifreeze, open the outside shower valves and blow on the hose. That would be all it would take to push enough antifreeze through the outside shower to protect it.
I couldn't stand the idea of a possible busted line especially since we will be headed to Florida middle of January. so I re-pressured the system and put the rv antifreeze through the shower only - worked good, thanks for the encouragement to do it right..
Old 11-18-2016, 06:15 PM   #14
Great job! You can rest easy now. Well... as easy as one can rest while waiting out the winter raring to go camping!
Days Camped: '15=22 '16=46 '17=30 '18=51
winter
