Old 10-17-2016, 10:13 AM   #1
winterizing water pump
So how best to do the water pump. There is no bypass on it.
I guess I just dump pink stuff in the main water tank and pump...
2015 grey wolf 27RR
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
Old 10-17-2016, 10:15 AM   #2
ilmor's Avatar
Correct.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 10-17-2016, 10:24 AM   #3
bubbles's Avatar
If you're just talking about the pump (with tank empty) why not just run it for awhile to expel residual water in it. Running it dry will not harm it.
Old 10-17-2016, 10:33 AM   #4
Why not install a winterization kit. It's just a length of hose and a valve.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 10-17-2016, 10:54 AM   #5
KenHwy61's Avatar
Do not put the antifreeze in the main water tank! You will use way more than you need to and it will be difficult to clean the pink stuff out come spring. As was suggested, you can make a winterizing system by attaching a hose to your pump inlet and putting the other end of the hose in jug of antifreeze. Then you can pump the antifreeze through. You can make it permanent by adding some valves. Don't forget to drain and bypass your water heater first.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is online now   Reply With Quote
Old 10-17-2016, 11:16 AM   #6
ilmor's Avatar
The spring sanitizing process takes care of cleaning the water tank. As for using way more than you need, well, I've done it both ways and used the same amount.
Old 10-17-2016, 02:49 PM   #7
Don't forget to winterize the city water line
Old 10-17-2016, 04:00 PM   #8
Another problem you may encounter is the water tank may have a low spot. There could be 3-4 gals of water left in the tank which would dilute the anti-freeze.
It is a 10-15 min job to install a winterization kit, that would be your best bet.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is online now   Reply With Quote
Old 10-17-2016, 04:14 PM   #9
WFD
I agree with installing a bypass valve...they are pretty inexpensive and readily available, then you are set up for future years. Agree with not putting pink stuff in the fresh tank. And I wouldn't risk just running a pump dry and being confident there is no water left in it. Expansion when freezing could permanently damage it.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-18-2016, 10:04 AM   #10
MainelyUS's Avatar
Check this out Camco Winterizing kit Install this once and next season winterizing will be a piece of cake.
Happy Trails
2015 Windjammer 2618VS (Hibernating)
2016 Silverado 2500HD Z71 6.0L 4:10 gears w/max. tow package
Reese Strait-Line WD
MainelyUS is offline   Reply With Quote
pump, water, water pump, winter
