If you use the air method, you might want to blow out the black tank flush as well. I did mine and could hear the sprayer rotating and did get some extra water to drain out, so it can't hurt. You could manually hand pump antifreeze through it instead if you don't do the air method first.
2017 Micro Lite 21DS
2018 Ford Expedition
