Old 09-24-2010, 07:55 PM   #1
Winterproofing a trailer
We just bought the Surveyor 189. Before we laid down the cash we were told it had Arctic Package. Turns out not on the Sport model.
There is several times we would like to use this trailer in the winter.
Has anyone ever covered the bottom of their trailer then shot or stuffed insulation in there?
madonafly is offline   Reply With Quote
Old 09-24-2010, 08:26 PM   #2
milzat's Avatar
You can cover the bottom of your trailer with Coroplast . Prior to enclosing the under-belly, install UltraHeat heating pads on your tanks and drain elbows.
Also, on the heated under-belly trailers, the heater ducts are run through the floor, snakes around the holding tanks, then exits into the trailer via floor registers.
Ultra Heat Video
milzat is offline   Reply With Quote
Old 09-25-2010, 09:26 AM   #3
THANKS! Milzat...awesome video.
