Originally Posted by tomiwanski
Thanks! Do you know if the Sunseeker as factory wired provides 12VDC to pin #4 to the plug on the motorhome?
Originally Posted by 270S
Don't know, but should have. Take a meter and test. Put meter on Vdc scale greater than 14, connect Red lead to pin 4 and Black lead to pin 1. You will read voltage being supplied. On my GT they forgot/removed the relay powering pin 5, so I suggest you check all Pins properly.
Check the voltage with the MH's ignition turned on and turned off, so you'll know if the power to the toad is "switched" (i.e., on all the time or switched off with the MH's ignition switch).
If it's NOT switched, you can end up draining your MH battery if not careful. To address this, you can either disconnect the 7-pin plug when necessary OR install a 12VDC relay that's either powered by something that's switched, or via an ON/OFF switch that you locate somewhere that's acceptable to you.
2011 Traverse LT, 3.6L, FWD
