Originally Posted by MarcH
pretty sure from just looking at others like the one shown are for cars, trucks, and vans. Never intended for travel trailer.
A tire pressure monitor only understands one thing. Pressure (and somethims temp too) but has no way of knowing what it's attached to.
TPMS systems DO have pressure ranges that match up with cars, vans, trucks so it's important to select a system that measures in the proper range. If you have one that will monitor pressures used in a travel trailer it really doesn't matter if "Travel Trailer" is listed in the suggested uses.
As for a $40 TPMS to monitor tires worth hundreds of dollars? I'm not that cheap.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
