09-19-2011, 08:00 AM
X-chocks vs Torsion Axles...
I need to do something to cut down on camper motions sickness, so I been thinking about buying a pair of BAL X-Chocks. Do X-chocks (or equivalent) work with torsion style axles?
It would seem to me that the front<-->back pressure inner wheel chocks put on the axles would place stress in the wrong places if you have dual torsion style axles.
Thoughts?
TV: 2008 Ford Expy
Camper: 2012 Rockwood Roo 233S
12V: 2 x Group 27 plus Honda Ex 700c Genset
09-19-2011, 08:10 AM
I use one because I'm too cheap to buy another!
Also don't have kids running around so movement is not so pronounced.
I don't have mine adjusted real tight but it seems to make a positive difference.
I put peel and stick stair tread material on it so it grips the tires better without needing
to be real tight.
(Looks like coarse very heavy duty sand paper.)
Peace!
Dan & Rita D
09-19-2011, 08:34 AM
I use these; a pair of them.
Rotochok Online
They help. But make sure your stabilizers are nice and tight too. Mine seem to loosen up after a few hours; probably the ground giving some. So now I go out and give them a tightening again later; it really helps.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
09-19-2011, 08:45 AM
Wanna Be Camper
We use dual X-Chocks with the torson suspension. They help but are not a total cure ans we have no issues with the suspension.
John & Deb
2011 Flagstaff V-Lite 30WRLS
09-19-2011, 08:54 AM
I use dual X-chocks and still have movement in the camper, I also have strong arms on the 5th wheel landing gear. Not sure what to do next?
09-19-2011, 10:24 AM
I use dual X-Chocks on our rubber torsion suspension. I have rear stabilizers and the front landing gear. That's it. As mentioned in a previous post, I go out after an hour or so and give the rear stabilizers a little more as they do seem to loosen or settle after a bit.
Unless you carry stacking jacks, and place them along the frame to take all the weight off the wheels and good support under the frame, I don't think you will ever get ALL the movement out. I just walk around in the trailer after disconnecting, then put the rear stabilizers down. So much better, and accept it for what it is. A mobile cabin on wheels, not a basement.
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
09-19-2011, 10:55 AM
BIA - I have your camper and use X-Chocks. They are a noticeable help but I will still feel the young ones moving on the rear bunks.
Other things that help to minimize the rocking is to use enough blocks under your tongue jack and each stabilizer so they do not extend too much.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
