Old 06-12-2015, 11:24 AM   #1
Yamaha vs Honda generators.
Looking at purchasing 2 2000 watt units to be run in parallel. Considering Yam's or Hondas. I like the Yam over the Honda for a couple reasons. The Yam has a fuel shutoff, oil level monitor and the overhead cam is gear drive vs the Honda belt drive. The only spec where Honda has the advantage is noise level, although the difference is negligible. From what I have found online both sets can be run from a larger auxiliary tank, which is a major must have.
Anyone have experience with the Yam's?
Brewhedd is offline   Reply With Quote
Old 06-12-2015, 11:29 AM   #2
B and B's Avatar
Have used both and found no real difference, Honda are the King and you pay for that. The Yamaha's are less expensive and the fact of gear drive vs a belt would sway me to purchase a Yamaha.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-12-2015, 11:41 AM   #3
alot of people also use the Champions, they are about half the price.
Last week, I ran mine at a campground at 8500 feet during the week next to a guy with a Honda 2000w. We compared them over beers and he concluded that for the money, he should have bought mine
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 06-12-2015, 12:55 PM   #4
I've been running dual Yamaha's the past 4 years or so and have no complaints. I chose them over the Honda's for many of the same reasons you mentioned. A timing belt doesn't excite me, and being able to run the carb out is a major feature for me since I don't really use them that often and don't want to have to go digging around to drain fuel.
One other thing that hasn't been mentioned yet.. the Honda's have a fuel pump while the Yamaha's do not. That's a pro and con. On the pro side it makes running an external tank easier with a Honda, but on the con side that is just one more component that can fail. With a Yamaha, as long as gravity still applies fuel feed is a non issue.
You can run an external tank with the Yamaha's (even though most Honda owners will tell you that you can't) but they have to be gravity fed or install a fuel pump to the external tank. There are internal pump mods that can be done, but then that defeats the purpose of a gravity fed genny.
I know Champion gensets get mentioned a lot. If you only do occasional camping that might be a good option. Personally, I don't use my Yamaha's often, but when I need them I NEED them and don't want to have to futz around to get em going. I also full time so I don't really want to sit around one place waiting for a repair. Reliability trumps price for me and I know that 10-15 years down the road, my Yamaha's will still be ticking along. In the event that a repair is needed, in-stock parts and repair centers for either the Honda or Yamaha are plentiful and most of the day to day maintenance parts can generally be bought off the shelf. Champion, service centers are pretty few and far between. The Honda/Yamaha's are also just marginally more fuel efficient.
Bottom line.. either Honda or Yamaha... I don't think you would be disappointed with either one.
With Champions... I kind of look at them a lot like batteries. Box store 6v GC's will certainly get the job done, but if you want maximum performance, reliability, with the longest life cycles.. you get a Trojan (or similar). A Champion will certainly save money, will get the job done... you get the picture.
Just my own take on it.
rana is offline   Reply With Quote
Old 06-12-2015, 01:17 PM   #5
My thoughts exactly! I have used both (honda and yamaha), I bought a yamaha at cabelas on sale and with a 4 year warranty. Couldnt be happier!
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 06-12-2015, 01:40 PM   #6
I have a Honda for 2 reasons:
1) local service
2) My camping buddies all have Hondas; if I bought a Yamaha and had any problems I'd never hear the end of it
2015 Shamrock 231KSS, Oyster shell
2016 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
55 nights camping 2015, 45 in 2016, 42 in 2017
CNYCamper is offline   Reply With Quote
Old 06-12-2015, 07:51 PM   #7
Big advantage of Yamaha and Honda over the competition is resale value. Things change in a few years and people will line up to give you a good dollar where you will GIVE away the competition.
larryo is offline   Reply With Quote
Old 06-13-2015, 10:43 AM   #8
That is a major issue. Looking online I found an extended run kit for the Yams that does not require the tank to be higher than the generator at PinellasPower. It has a fuel pump of some type for the tank, downside is they want $250 for it without the tank. A machined cap is also available for gravity feed but you would have to fabricate everything else and I'm not sure how that setup would perform. There is not much info online about the gravity feed tank setup and if it will actually work without leaking at the cap. Obviously leaking gas could be devastating.
As much as I like the Yam's for the reasons already stated I may go with the Honda's due to the fact that Wise Sales sells a "plug and play" extended run tank that is proven.
Old 06-13-2015, 11:13 AM   #9
Who Dares, Wins
doc73's Avatar
Never run a Yamaha but I run two EU2000's when the extra juice is needed for the A/C. I love them, start every time usually on the first few pulls (do not use them a lot and start them bi-monthly without draining fuel). They are super quiet and half the time I do not even know they are running outside my camper window let alone the next site. I like the extended tanks as well for them using the boat fuel tanks.
I did the Honda over the Yamaha because I have a Honda small engine shop 10 minutes away.. The closest Yamaha, no idea... But not around here.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-13-2015, 12:10 PM   #10
wanderer69's Avatar
Quality wise there is no difference between the two. Its just the features that you mentioned. The fuel shut off was important to me because of the junk in the gas produced now that can cause problems for the carburetor if left sitting. You haven't mentioned what the reason for the extended run tank is. I bought the Yamaha's 2 years ago and would make the same purchase again. I also considered the extended run tank but decided to wait and see if I really needed them. Glad now I didn't buy them because in the two years of full timing a lot of which was dry camping I have never had occasion to need one. Keep in mind that in most of campgrounds there will be restrictions on the hours that you can run a generator. If you are going to buy 2 and want to save some money check out a company on the web called AP Electric out of Pleasant Prairie, WI. If you buy the combo set they include the parallel cable kit and 2 engine covers and free shipping and no sales taxes since you live in Florida for $1978. That's a good deal. That is where I bought mine. Don't forget to get a tach/hour meter for them so you know when to service.
Yamaha EF2000iS | Yamaha 1600W Inverter Combo Package | AP Electric
Tom
2015 Chevrolet Silverado LTZ 3500 CC DRW Diesel
2014 Cedar Creek 36CKTS
wanderer69 is offline   Reply With Quote
generator
