Old 10-23-2013, 11:06 AM   #1
Chrisbrock's Avatar
Send a message via Skype™ to Chrisbrock
Your Gas MPG sweet spot
So I am just getting some feedback from all the other RV addicts out there. I have been really monitoring fuel economy and trying to max it out while on the road. Obviously on the interstate in cruise control is the best scenario but does anyone have a idea of what speed or RPM's is the best for MPG?
It looks like on my end that around 55mph / 2000 rpm is the best. Thats with my tires at 80psi (max cold), tanks empty except for about 1/4 of a tank in fresh and 1/2 tank in fuel.
Any thoughts?
Christopher Brock
2014 Sunseeker 3170ds
2012 Honda Odyssey
2003 Hummer H2
2003 IS300
Chrisbrock is offline   Reply With Quote
Old 10-23-2013, 11:23 AM   #2
kenandterry's Avatar
DW and I just did a run from Canada to St. Pete's Beach Florida with our 2010 Georgetown 330TS towing our 2006 Pontiac G6 toad. We wanted to get the rig into warmer climates so we wouldn't have to worry about winterizing. We will return South right after Christmas and spend the winter hiding out in warmer temps (we hope)
In the MH, we were packed with all our clothing we'll need for our time there. Food-wise, only non-perishables on board. Everything else is always on board to survive comfortably.
I set the cruise religiously at 60MPH for the entire trip. The specs for the toad specify NOT to exceed towing at speeds over 65MPH.
The result? Calculations showed 7.8mpg for the 1568 mile trip.
That Ford V-10 does the job perfectly, and seems to provide mileage in line with earlier posts for fuel consumption.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 10-23-2013, 11:26 AM   #3
Resident Masshole
force's Avatar
A surprisingly complicated question. I read a long time ago the sweet spot for MPG in most vehicles was about 45mph.
This is a pretty good read on the topic:
HowStuffWorks "What speed should I drive to get maximum fuel efficiency?"
It claims the sweet spot is between 40-60mph, all caveats considered.
Tom F.
2013 GMC 2500HD SLT Crew Cab
2013 Rockwood Roo 23SS
Nights camped in 2014: 8
Nights camped in 2013: 30
force is offline   Reply With Quote
Old 10-23-2013, 11:42 AM   #4
Chrisbrock's Avatar
Ken, agreed the v10 is perfect for the MH. I am pleased with the all around performance on the 2014 E450 Ford.
7.8mpg sounds about spot on. I am not pulling anything so I might get a tad better but the Scan Gauge shows around 9mpg at 55mph
Christopher Brock
2012 Honda Odyssey
2003 Hummer H2
2003 IS300
Old 10-24-2013, 12:08 PM   #5
pt1655's Avatar
hidee ho
I don't give much thought to MPG anymore; I just tow at 60mph and let it be. That is my comfort speed and the truck seems quite mellow at that speed; any lower and it lugs too much and higher is too hard on the trailer tires and wind resistance. My Ram has a 6sp automatic, Vararam intake, tonneau cover and Bullydog Gt tuner for the hemi and it just purrs at 60 with those mods. I do use the cruise control as much as possible but also use the up/down switch on the gearshift lever whenever I can anticipate the need such as a hill or passing or whatever. Coming back from Benson, Az to northern Az where we live last week I got a high of 13.5 mpg at 60 so I'm ok with that. I've also seen a low of 7mpg against a heavy headwind uphill so it all evens out!
Happy camping!
2013 Forest River Surveyor SP220 Sport 25'
2012 Ram 1500 4X4, 5.7L Hemi quad cab
pt1655 is offline   Reply With Quote
Old 10-24-2013, 06:21 PM   #6
Having A Ball's Avatar
In my 2004 f250 powerstroke I found 65-68 is nice on the tank pulling my 5th wheel.ill get about 11-13 mpg on flat. Now when I pull my 30ft v nose car hauler with my 61 t bird loaded, I'm more like 9-10 mpg.
I have put a programmer, banks intake, exhaust to get these numbers, before it was a flat 8-9 mpg no matter what I pulled.
Having A Ball is offline   Reply With Quote
Old 10-24-2013, 06:45 PM   #7
psaman's Avatar
60 mph at about 2000 rpm here, gives us anywhere from 8.9 to 9.9 depending on the wind.
2012 Freedom Express 295 RLDS
2011 Ford F-150 Texas Edition
Prodigy P2 Brake Controller
psaman is offline   Reply With Quote
Old 10-24-2013, 07:02 PM   #8
bubbles's Avatar
If there was such a thing as a MPG sweet spot it would have to be, set up and kickin back with a cool one at the destination.
Old 10-24-2013, 07:58 PM   #9
55 MPH! Youroo!!
ID:	41714   Click image for larger version
Old 10-24-2013, 08:11 PM   #10
Originally Posted by youroo View Post
55 MPH! Youroo!!
No fair shifting into neutral and coasting.
gas, mpg
