Old 09-27-2015, 02:48 PM   #1
3600RS Pimples under wall paper
Hi All,
I have a 2013 3600RS, and just last week i noticed a bunch of pimples forming under the wall paper, and while i was inspecting the rest of the camper, i actually found a mushroom formed under the paper. I did cut it out and around the area was a bunch of black mold.
I have these pimples formed in the bedroom slide, main slide, back of camper, opposing slide, pretty much in all exterior walls. i also did have a small roof leak over the main slide that was a factory fault when they sealed the rood they missed a small section, i did get the leak repair using eterna-bond.
the damage from that leak caused the underlay for the wall paper to bulge.
OK so i did call my insurance company to look to see if they can help, no word yet from them but he was worried it may be a factory issue with the underlay board being wet from factory.
Can anyone here give me some ideas what i can do with this, i love my camper, its the older model with the computer desk area?
Does FR have a known issue with these panel boards?
I wouldn't be so concerned but the fact that it is occuring all over the camper on all exterior walls almost make me think it may have a bigger issue?
2017 F350 CC 6.7L Diesel Bronze Fire Lariat
2013 Blue Ridge 3600rs
dpercival4 is offline   Reply With Quote
Old 09-27-2015, 06:54 PM   #2
Major's Avatar
Sorry but I can't help. We have a 2014 3600RS and have not seen any issues like this.
Doug and Becky Ridgeway
2014 Blue Ridge 3600RS
2014 Ford F-350 CC 4X4 DRW 6.7 PSD
Troy, NC
Major is offline   Reply With Quote
Old 09-27-2015, 07:00 PM   #3
It may not be healthy living around that mold. Should find some articles online about moldy drywall issues in homes, basements and health issues.
Dobe Fanatic - Largo, Florida
2012 Flagstaff T12RB A-Frame
DobeFanatic is offline   Reply With Quote
Old 09-27-2015, 07:05 PM   #4
No thats why we are not using it right now, I would be ok if it was only just a spot here and there but since it is every exterior wall it has me concerned pretty good. We have had very little rain here too which i am trying to figure out what is happening
Old 09-27-2015, 07:14 PM   #5
Found this right away:
could pick up a mold test kit in the paint department of HD or similar. They are probably under $10. You may not wish to send to a lab for testing, but the amount of growth in the petri dish will confirm or deny the presence of mold. Afterb that, if you want, you can send it to the lab listed on the paper and for about $50 they will tell what kind of mold and in what amounts.
Old 09-27-2015, 07:22 PM   #6
I am more looking is there anything i can do the insurance company thinks it a manufacturing issue. should be no reason for mold and mushrooms to be growing between the wall paper and the plywood. the walls on the inside have not been wet, except for the 1 area the leak occured. i also have owner this from new
Old 09-27-2015, 07:31 PM   #7
garmford's Avatar
We had the same problem with our 2013. We had pimples on the wall which turned out to be a roof leak. Blue Ridge made a huge design flaw in that model year. They thought it would be a good idea to terminate the roof membrane on top of the roof and caulk it into a metal flashing instead of taking the rubber over the sidewall and terminate it into the rain gutter. We had pimples soon after we bought our camper in August of 2013. FR took our camper back to the factory in late winter of 2014 to fix it but only put a band-aid on it. In Sept of 2014 we had major pimples again so I contacted FR and with a little push from me they came a took my camper back to the factory again in February of this year and fixed it right!! They replaced the entire roofing membrane and took it over the side walls and terminated it into the rain gutters. Knock on wood I haven't seen any bubbles and feel pretty confident that I won't see any again.
The only thing I can say is to contact Forest River and see what they can do for you!! I don't have their contact info on hand but I know I can get it to you if you want it. Stay strong!! You will never get rid of the pimple problem until the roof is installed correctly. You will have way more damage than the pimples if nobody corrects this problem for you. I do wish you luck!! My heart absolutely sank the first time I found out what the pimples were from. The second time we found pimples after they "fixed" it I almost got physically ill! Lol. But I have to say that Forest River took my camper twice back to the factory for repairs with absolutely no cost to me. They also fixed things that weren't even on our list. Please keep us informed on what happens!!!
2012 F350 DRW 6.7 PSD
Blue Ridge 3710 BH
garmford is offline   Reply With Quote
Old 09-27-2015, 07:41 PM   #8
If you can please do i would greatly appreciate it
Old 09-27-2015, 07:46 PM   #9
asquared's Avatar
You need to contact FR directly and explain the situation to them. Here is the blue ridge contact info.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 09-27-2015, 08:19 PM   #10
garmford's Avatar
Warranty Manager
Terry Milarczyk
574-206-7618
Tmilarczyk@forestriverinc.com
This is who I dealt with. He was
very friendly and accommodating!
Good luck !!
Blue Ridge 3710 BH
Old 09-28-2015, 11:52 AM   #11
Wolverine 1945's Avatar
Sounds like the wall board was wet when they built the unit ???
DEFFINLY contact FR,,, Hopefully you will not need a lawer !!!
Wolverine 1945 is offline   Reply With Quote
Old 09-29-2015, 08:10 AM   #12
SilverbackMel's Avatar
I had a 2011 new Keystone with a similar leak. Mine was from a leaking window frame.
You can find my recent FR experience ( POSITIVE RESULTS) under Cedar Creek. ( Silverbackmel)
JUST returned from Indiana last week after having many issues resolved. Follow the posters contact suggestion and lay out the issues. REMEMBER THIS: the person you speak with CAN help you! ALSO, they DID NOT personally build your RV. Try the soft sale approach and do not lose your cool. Those suggesting a "lawyer" is a direction you ONLY TAKE AFTER YOU HAVE EXHAUSTED EVERY REASONABLE EFFORT TO RESOLVE YOUR ISSUES DIRECTLY. Don't think for a minute that FR does not have a crack legal team as well.
Good luck! FR is on a track to improve customer satisfaction.
Give them the opportunity to prove it!
SilverbackMel is offline   Reply With Quote
Old 09-29-2015, 08:14 AM   #13
garmford's Avatar
Well put Mel! I totally agree!! I always believed that if you kill them with kindness you tend to have better results. I dont have any complaints with the service I received from forest River.
Blue Ridge 3710 BH
Old 09-29-2015, 08:23 AM   #14
Of course you guys are right about Lawyer being your last option !!!
I am saying I hope it does not get that far !!!
Also I hope SilverbackMel is right about FR improving satisfaction ???
Service @ FR is pretty good,,, it is to bad so much is needed !!!
Old 10-29-2015, 04:52 PM   #15
garmford's Avatar
Do you have any updates? I hope you're having good luck!!
Blue Ridge 3710 BH
Old 10-29-2015, 07:15 PM   #16
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
[QUOTE=Wolverine 1945;996630]Of course you guys are right about Lawyer being your last option !!![QUOTE]
Forest River may operate like industrial companies I've worked for in the past. As soon as a complainant mentions going to an attorney, all future conversation must cease and corporate legal needed to be notified. The moral to the story is, if you want to mention "lawyer", don't expect anymore to be done on your issue until your attorney gets involved. Be careful using that threat to get satisfaction because there can be many negative results.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 10-30-2015, 06:57 AM   #17
Yep, i do have an Update, talked with forest river, Called them right after i sent updated photos to Dan Dobecki, very nice gentleman, just was nice to deal with, he asked a few simple questions, looked at my pictures and then said he would like to bring it back to factory for repair. Having a transporter come in January for repair at the factory. I never had to talk mean, or even get upset. Glad FR is taking care of this issue.
Glad they are standing behind their product
Old 10-30-2015, 07:51 PM   #18
garmford's Avatar
That's great news!! Glad to hear that they're gonna take care of you!!
Blue Ridge 3710 BH
Old 10-30-2015, 07:51 PM   #19
Major's Avatar
I strongly urge all Blue Ridge and Cardinal owners to go to the following site:
CARDINAL RV CLUB
Look under Board index Miscellaneous Discussions Cardinal/Blue Ridge Corner Possible Wall Pimple Cause
There is an entire thread on this issue. Cardinals and Blue Ridge RV's are not properly "sealed" on the slides which will cause water "wicking" along those slide seals that infiltrates the structure walls.
To fix it, you just need to silicone the outside of the "D" seal on top and sides. I did this on mine after I noticed a small area of pimples on the wall beside the kitchen slide.
This is one of those "maintenance things" everyone hates to do but if you want your RV to last, it needs to be done. Many on the Cardinal Club site have told of this issue.
Troy, NC
Old 07-24-2016, 04:19 PM   #20
jacknife's Avatar
Do not use silicone. Use the black non settling flex seal. Just passing on info gained from pros.
jacknife is offline   Reply With Quote
