Old 07-16-2018, 01:19 PM   #1
kaj
Blue Ridge 5th wheel - slides won't move
I have a Blue Ridge 5th wheel with hydraulic slides (3 slides- 1 control). the slide has stopped working - at this point it is 3/4 the way out. Any ideas what could be wrong and how to fix?
kaj is offline   Reply With Quote
Old 07-16-2018, 01:26 PM   #2
Check all fuses, both in the main fuse panel and between the battery and pump. Also check charge in batteries as low batteries can cause fuses to blow.
Old 07-16-2018, 02:08 PM   #3
kaj
All fuses and batteries have been checked as well as hydraulic fluid
Old 07-16-2018, 05:52 PM   #4
Maybe time to call mobile RV service....
Old 07-16-2018, 09:35 PM   #5
Check the battery circuit breakers. They can be reset
Okie Dokie 2 is offline   Reply With Quote
Old 07-17-2018, 12:33 PM   #6
Try a jumper over the auto reset breaker at top of bus bar. I replaced mine
sailtrkr is offline   Reply With Quote
Old 07-17-2018, 01:14 PM   #7
Let us know the outcome so we can all learn. Thanks!
Not every RV with hydraulics is setup the same. Mine is an older one and has no type of resettable fuses/breakers in relation to the pump and valves. I only have 2 inline fuses and one fuse in the fuse block.
Old 07-17-2018, 01:21 PM   #8
149252's Avatar
What model and year. I too have Blue Ridge with 6 point with manual.
2016 Ram3500 4x4 SRW 6.7 68RFE 3:42
2014 Blue Ridge 3125RT
PullRite Super Glide
149252 is offline   Reply With Quote
Old 07-17-2018, 01:41 PM   #9
bend302's Avatar
When the hydraulic slide on my Georgetown failed I had to replace the reversing solenoid. My leveling jacks had failed too. Took a mobile repair tech to show me what was wrong. But I was able to replace myself.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 07-17-2018, 08:44 PM   #10
New to FR. Old to TT
Unhappy
we have control valves that allow you to not run a slide or to only run one. check to see if all the valves are turned to the open direction. should have asked first if your pump runs and if any other slides move in and out if so then check valves if not don't pay any attention to this
2018 GMC 2500 Denali HD ,Duramax with Allison trans.
2019 Cedar Creek 36ck2
Tall frog is offline   Reply With Quote
Old 07-18-2018, 09:47 AM   #11
Control valves I like that idea.
jeepin1 is offline   Reply With Quote
Old 08-29-2018, 01:06 PM   #12
kaj
Circuit board had to be replaced.
Old 08-29-2018, 01:26 PM   #13
Thanks for the update!
5th wheel, blue ridge, slide, wheel
