Old 07-01-2016, 08:54 PM   #1
Unhappy Front Jack Switch making slides come out?
We have a 2014 3125 Blue Ridge camper that we have had since brand new. We went to hook it up tonight to go camping and the front jacks will not come up. All the switches for the from jacks are for some reason making the slides go in and out. The slide switches also work for the slides. We have never had this happen before! HELP
Jharrah is offline   Reply With Quote
Old 07-02-2016, 07:40 PM   #2
garmford's Avatar
Were you able to figure it out? I've never heard of this happening before but I would guess that one of the solenoids may not be functioning properly.
I'm curious to know what you find out.
Good luck!
2012 F350 DRW 6.7 PSD
Blue Ridge 3710 BH
garmford is offline   Reply With Quote
Old 07-06-2016, 06:59 PM   #3
I recommend manually closing the shutoff valves for the slides so the pump can only operate the front jacks. Cycle them up and down a few times to verify they work correctly. Then shut off the front jacks' valve and open/cycle one slide at the time. Then open all shutoff valves and try independent operation.
2014 Blue Ridge 3715BH <- Read the saga
2013 Sierra 3500HD Denali CCLB DRW 4x4 Duramax w/ Reese 20K
USN Retired (26 years), but not Retired retired
Home Port Orlando
Narboza is offline   Reply With Quote
slide, slide out
