I own a 2014 3710BH ....I am in the market for a generator.....how big should I get in other words what is the best for that unit.....thanks in advance...!!
You have asked a question that is a good one but we need a little more information. What are you trying to run with the generator? Do you need AC? What about other things like TV or space heater/ fireplace.
That will just work, you did not state built in or external. Sorry about that. If you run propane as fuel expect to use a lot to keep 2 ac units running.
Just thought I would weigh in I have a Diesel 6000 Onan and it works everything, two ACs and TVs not sure if I tried the ACs with the microwave, I will try that next time I go out.
All the Diesels are the same size so at least I know they will fit, I bought this one used and had it gone through,
Is your 6000 just diesel or duel......looking for propane.....I am looking for a 5500 or 6500....and yes all plumed for the generator.....harness and remote switch box.....do not have exhaust tube or wiring harness yet.....
Just Diesel I figured my Truck is Diesel so I carry some extra Fuel when we are traveling, can use on either one.
The Diesel Gen will run almost forever on the take I have.
Nice.....I have a diesel truck but run the RV on Propane.....still deciding.....guess bottom line I am a tight ass and don’t want to spend the cash but I will have to.....thanks for your input....where did you locate a used onin..??
