Old 04-06-2018, 08:32 PM   #1
Shep
Generator
I own a 2014 3710BH ....I am in the market for a generator.....how big should I get in other words what is the best for that unit.....thanks in advance...!!
libby04 is offline   Reply With Quote
Old 04-06-2018, 09:00 PM   #2
B and B's Avatar
Hello and welcome to the Forum,
You have asked a question that is a good one but we need a little more information. What are you trying to run with the generator? Do you need AC? What about other things like TV or space heater/ fireplace.
Looking to assist in a solution
Cheers
Old 04-06-2018, 09:17 PM   #3
Shep
At least both ACís .......
Old 04-06-2018, 09:31 PM   #4
B and B's Avatar
You will require at least 7kw Generator to run 2 15k BTU AC units
https://powerequipment.honda.com/gen...odels/eu7000is
Old 04-06-2018, 09:32 PM   #5
Shep
What about a Onin 6500.....
Old 04-06-2018, 09:45 PM   #6
B and B's Avatar
That will just work, you did not state built in or external. Sorry about that. If you run propane as fuel expect to use a lot to keep 2 ac units running.
Old 04-06-2018, 10:00 PM   #7
Shep
Sorry about that....I have read that the 6500 is more due efficient than the 5500.....and yes built in......
Old 04-09-2018, 03:49 PM   #8
Just thought I would weigh in I have a Diesel 6000 Onan and it works everything, two ACs and TVs not sure if I tried the ACs with the microwave, I will try that next time I go out.
All the Diesels are the same size so at least I know they will fit, I bought this one used and had it gone through,
Is your rig wired for a Generator ?
ID:	167658   Click image for larger version
ID:	167659   Click image for larger version
jeepin1 is offline   Reply With Quote
Old 04-09-2018, 04:22 PM   #9
Shep
Generator
Is your 6000 just diesel or duel......looking for propane.....I am looking for a 5500 or 6500....and yes all plumed for the generator.....harness and remote switch box.....do not have exhaust tube or wiring harness yet.....
Old 04-09-2018, 04:27 PM   #10
Just Diesel I figured my Truck is Diesel so I carry some extra Fuel when we are traveling, can use on either one.
The Diesel Gen will run almost forever on the take I have.
Old 04-09-2018, 04:29 PM   #11
Shep
Nice.....I have a diesel truck but run the RV on Propane.....still deciding.....guess bottom line I am a tight ass and donít want to spend the cash but I will have to.....thanks for your input....where did you locate a used onin..??
Old 04-09-2018, 07:24 PM   #12
Craigslist,I lucked out,
generator
