Old 03-26-2018, 08:37 PM   #1
Hard Wire Surge Protector in 2017 Blue Ridge
Bought a Progressive Industries EMS-LCHW50. Has anyone installed in a 2017 Blue Ridge 2910sk? Not sure where to install it? Instructions say after the Transfer box, not really sure where that is either. Thanks for your help.
lqtena is offline   Reply With Quote
Old 03-27-2018, 08:40 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. I don't know your rig so I really can't answer I'm sure someone with have a suggestion.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-27-2018, 08:51 AM   #3
AquaMan's Avatar
You would only have a transfer box if you have an onboard generator, and most of us install before the transfer switch. That said, if you don't have an onboard generator, the most common place is behind the fuse panel. This generally works for most units. You can pull 4 screws and the breaker/fuse panel (converter) will pull out. Wire the EMS just before the converter. This is the easiest, but only works if you have the unit with the remote display. If you don't have the remote display, you can still run wiring into a basement storage area and mount there.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
blue ridge
