Old 08-29-2011, 11:48 AM   #1
Kinda Bummed
Spoke to a Forest River engineer in the Blue Ridge/Cardinal division in Ill. and voiced my concern over the pin weight and what our trucks payload is. Wanted to know exactly how they, as a manufacturer, determine the pin weight when it leaves the factory. We would be over our payload...just no way around it. He also says that the Blue Ridge's and Cardinals are meant to be pulled by 1 ton trucks and 3/4 ton is really pushing it although people do it. Well its definitely safety first for us andwe travel up and down high grades and thru mountain passes and canyons so I think this one is out due to weight issues. I really loved it but we don't want to put purselves or anyone else in danger on the road....so our search continues.
JJ & Sandie 2 little chihuahuas and 1 kitty. 2011 Chevy 2500HD LT XC Diesel. 2008 Aruba fiver and seriously considering the 2010 Blue Ridge 3125RT.
sacuna is offline   Reply With Quote
Old 08-29-2011, 12:16 PM   #2
TURBS's Avatar
thats to bad ............ what was the pin weight of the one you were looking at ? and what is your tv ?
Old 08-29-2011, 12:22 PM   #3
Dry pin according to label is 1975#....our trucks payload is 2600#, but you also have to add into that the weight of the hitch, all fluids, people in the truck and cargo. It just doesn't add up even without weighing everything at a weigh station. Steve, the engineer at Forest River, suggested that that dealer pull that fiver to a weigh station as is with nothing in it and see exactly what tht pin weight is on that particular unit...could be less, could be more but I wouldn't think it would make much difference either way at this point.
Old 08-29-2011, 12:28 PM   #4
TURBS's Avatar
bummer .
good luck ! and hopfully you find somthing you like with out not getting what you want.
Old 08-29-2011, 05:53 PM   #5
Good decision - it's not worth your life. I know many people pull too much and never have a problem; but my luck is not that good.
Keith & Liz
2010 SilverBack 33L
2009 F-250
kablair is offline   Reply With Quote
