Old 08-24-2011, 09:57 AM   #1
Met with dealer yesterday
Went to go and see the 3125RT again and did a thorough walk thru checking everything except the water faucets, toilet, shower or anything to do with water as they didn't have the water hooked up, just the electric. Frig was good, a/c was good, but it was 115 degrees outside so it was tough to keep it cool with those temps but it was blowing out cold air. Some minor fit and finish items need to be taken care of but all in all everything seemed to work good. Pulled slides in and out and the awning, tv in living area, no problems. One thing is the tv in the bedroom. How in the world do you either remove it from its braces to get your satellite cable attached? They need to figure that out and show us or replace it with an adjustable arm so we can get back there...they said it would be taken care of in the PDI. OK....we'll see. Haven't totally committed to it yet...told them we will let them know in a few days. What do ya think???
sacuna is offline   Reply With Quote
Old 08-24-2011, 10:05 AM   #2
TURBS's Avatar
the tv lifts off of the bracket in question. At least most do . They lift straight up .
I also say congrats on a new unit ! woooo hoooo !
Old 08-24-2011, 03:43 PM   #3
cardinal4fun's Avatar
Please just make sure when you do the pdi to have water for the unit. You want to beable to not only check the all of the faucetts etc but the water pump, make sure nothing leeks anywhere while under pressure.
enjoy
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
