Old 09-19-2013, 09:29 AM   #1
149252's Avatar
Smile TV connections
How would I get a schematic of the cable TV connections in our new 2014 3125RL. When I did a walk around with the dealer, he could not answer the question and new very little about the unit. The service rep that was to show the 6 point landing operation, told us to read the book. I really hope that I do not have any problems with this unit.
149252 is offline   Reply With Quote
Old 09-19-2013, 09:43 AM   #2
You probably won't find a schematic. This may help.
There is probably also a Satellite dish connection point on the outside of your RV which will just be a direct connection to a Sat. connector on the inside of your RV. (They seem to often swap one end or the other of the Sat & Cable wires so if something isn't working, look at the wire colors to see if they did that.)
In case you don't know, Antenna Booster Control Off (no light), Cable-In is connected to the TVs. Booster On: Antenna connected to TVs.
Old 09-20-2013, 05:27 AM   #3
etcmss's Avatar
schematics
I had the same question after purchasing my Flagstaff. I figured it out (some previous experience with a Class A and C).
is there anyone that has influence over Forest River to update owner manual to provide the basic drawing like the above?
might include basic plumbing.
Gary
etcmss is offline   Reply With Quote
Old 09-20-2013, 08:17 AM   #4
149252's Avatar
Cable
My last 5er was a North Shore by Dutchman and in the manual it had a schematic for the TV cable. When I look behind both TV's on this Blue Ridge there are connectors for two lines, now is one in and one out I don't know, also in the storage compartment there is two cables left hanging one audio and TV, I think. There is also a connector for satellite in the utility docking station.
So many connections ??????
2016 Ram3500 4x4 SRW 6.7 68RFE 3:42
2014 Blue Ridge 3125RT
PullRite Super Glide
Old 09-20-2013, 08:42 AM   #5
Originally Posted by 149252 View Post
... When I look behind both TV's on this Blue Ridge there are connectors ...
One connector will be from the antenna splitter. My guess is that the other connector (at the second TV) is because they put a splitter on the Satellite cable, usually a bad thing to do. You'll have to find and remove it if you want to use satellite.
Old 09-20-2013, 09:00 AM   #6
149252's Avatar
Now I know how I can spend this weekend, try to connect my satellite and see what I can see. Life is full of surprises. Boy am I ever glad the Dealer helped me when I purchased this unit.
Old 01-26-2014, 08:12 PM   #7
BlueRidge 3025RL
Don't forget that in the 3025, the tv booster is above the tv in rear bedroom. Make sure you turn it off when using the cable, sometimes the antenna when on, bypasses the cable input.
thomas.jackson is offline   Reply With Quote
