Old 12-09-2017, 09:08 AM   #1
rmshorter's Avatar
Water leaking under the slides
Water from the road coming in under the kitchen slide. Had tire blow out 2 months ago on that side but donít see any damage underneath to the seal. Replaced all the tires with G614
I have 2015 Blue Ridge 3600RS. Been on the road off and on for last 2 years but havenít driven through the amount of rain that has been coming down in Texas.
Any ideas?
Robert Shorter
2015 Dodge 3500 DWD
Blue Ridge 3600RS
rmshorter is offline   Reply With Quote
Old 12-09-2017, 09:27 AM   #2
2017 Windjammer 3029w
My 2017 Winjammer does same in kitchen in rain while driving. Brought it in to shop and they replaced under seal, but we drove early this week in rain and problem continues. Mine comes from wheels throwing up water but now will be bringing it back again for repair.
Nederland, Texas
Dastagg is offline   Reply With Quote
Old 12-09-2017, 09:58 AM   #3
rmshorter's Avatar
Please update me what actions they will take and if it fixes the leak, thanks
Robert Shorter
2015 Dodge 3500 DWD
Blue Ridge 3600RS
Old 12-09-2017, 10:58 AM   #4
I will. Plan on bringing it in next month. They changed bottom seal last time (at least told me that) but still gets wet while driving in the rain. Hard to check out when not raining 2hich is most times we travel.
Nederland, Texas
Old 12-09-2017, 11:36 AM   #5
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
We had this problem on our 2014 Trilogy, the bottom seal was replaced under warranty, never had water come in after.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 12-09-2017, 06:41 PM   #6
Take a closer look at the seals. I had whose that was intercepting with seal
Big Bill is offline   Reply With Quote
Old 12-10-2017, 10:57 AM   #7
Traveling Two
jerryliving's Avatar
I had the same problem. I discovered that the seal strip to cover the gap was actually missing. I looked at a similar trailer and saw the strip was not installed on our trailer. Tried to get the local shop to install (we were traveling and had hit a rain storm) the strip but was too busy. He provided me with the materials and I did it myself. Never had another problem.
jerryliving is offline   Reply With Quote
Old 12-10-2017, 11:17 AM   #8
I would just like to point out how important it is to pay attention to the areas around the slideouts, and to make sure all external seals are always folded out properly when the slides are extended. We have seen quite a few used rv's at dealerships with soft spots near slideouts and even near windows.
If this kind of water intrusion gets missed or ignored, carpet is bad as it tends to cover the wet spots, it can lead to irreparable rot in a very short time.
Old 12-10-2017, 11:27 AM   #9
rmshorter's Avatar
Jerryliving, do you have pic(s) with the seal strips installed?
Robert Shorter
2015 Dodge 3500 DWD
Blue Ridge 3600RS
Old 12-11-2017, 03:13 PM   #10
rmshorter's Avatar
ID:	158124Click image for larger version
ID:	158125Click image for larger version
ID:	158126Click image for larger version
ID:	158127Click image for larger version
ID:	158128Click image for larger version
Robert Shorter
2015 Dodge 3500 DWD
Blue Ridge 3600RS
Old 12-11-2017, 03:15 PM   #11
rmshorter's Avatar
I attached pictures of the underneath of the kitchen slide. Whatís missing? I donít see any damage. Thanks
Robert Shorter
2015 Dodge 3500 DWD
Blue Ridge 3600RS
leak, slide, water, water leak
