Old 08-04-2015, 07:09 PM   #11
Hello everyone in this post! We're 163X owners and have been since fall 2013, actually! We totally agree, we've only seen one other 163X "in the wild". We see a few of them at the dealer we bought our from and that's it! We really don't understand why as we love ours. We see the Roo's and other similar styles, but we get all the looks when we press the button for the awning!
Our ONLY complaint is a leak in front bunk. I've tried recaulking (per dealer) and still there! Of course, we're outside of warranty ranges. Any ideas?
btw, tip of the decade! Get some Reflectix insulation and cut it to the ends. It's awesome awesome!!! Helps keep it warm/cold plus blocks out unwanted sun at 8am (we like to sleep in)
paulandsarah is offline   Reply With Quote
Old 08-04-2015, 09:54 PM   #12
2014 Solaire 147X
RamsFan1's Avatar
We also purchased our 147x in the fall of 2013 and have never seen another Solaire "in the wild."
Knowing what we know now about towing (our first TT), we wish we had gone with the 163x for the little extra room it has.
Where is your leak, which bunk and is it when open or closed?
2011 Chevy Traverse
2014 Solaire 147X
RamsFan1 is online now   Reply With Quote
Old 08-04-2015, 10:54 PM   #13
I should have included those facts... the leak seems to be when it's open though we MAY have seen it when closed (per wife). It's the front bunk. As far as the 147x, there's not THAT much more in the 163x. In fact, I'd say the deciding factor between the two should be one or two axles. Also, the weight difference. With our tow vehicle, we should have went with the 147x... but! We're happy and that's what matters
Old 08-05-2015, 08:19 AM   #14
2014 Solaire 147X
RamsFan1's Avatar
Looking at ours, I would suggest checking the 4 corners (upper/lower left and right) where the canvas attaches to the trailer, from both inside and outside the bunk. Looking for any little gaps where water could get in those areas would be where I would look first.
Glad to hear you are happy with your 163x as we are too!
2011 Chevy Traverse
2014 Solaire 147X
Old 08-26-2015, 07:23 PM   #15
We bought our 163x in May and have been out just about every weekend since we got it home. We love it! No problems, great prep by the dealer and with the Equalizer hitch it tows behind the Explorer like a dream. We added a power front jack as recommended by the person that prepped it for us. Well worth the extra money as cranking it up and down on the hitch would have been painful for this old guy. Hope you all enjoy your Solaire as much as we do. We are in Bar Harbor ME this week and having a great camping experience. Acadia National Park is beautiful.
Pilot172 is offline   Reply With Quote
Old 06-16-2016, 01:23 PM   #16
New 163x owner
Hello everyone,
My wife and I recently bought a used 2014 163x.
I have a couple of newbie questions, as this is our first RV
(tenting 30+yr).
First concern is the 12v batteries. We picked it up last month, from a local dealer, and it's been sitting in the back yard since. When I hooked it to the truck last night, I noticed the RV battery was close to dead. I know that over time the battery will go dead, but it's only been 5 weeks. I want to know if there is a master switch that needs to be shut off, or is this normal. I know some like the clock, and radio are still on when everything else is shutdown.
Also, I don't have 30a at home, so can I just plug in my dogbone, and charge the battery with 110 ?, or do I hook up a battery charger to one of the batteries. If I can just plug in the dogbone, is there a switch to activate or just plug in, and that's it. What kind of charger do I need? Can I use a car battery charger?
I know it should charge once I hook up to 30a, but I would like to charge it before we leave in the next couple of days.
Question #2, are there any useful links for understanding/troubleshooting the Electrical system ?
Thanks for any suggestions, and again, sorry for the newbie questions.
Rick
2ooler is offline   Reply With Quote
Old 06-16-2016, 02:02 PM   #17
Moderators' Assistant
bikendan's Avatar
Google "The 12 Volt Side of Life" to learn about RV electric.
You're lucky the battery lasted that long without being plugged into shore power.
RVs have numerous parasitic power drains.
You may have damaged the battery by allowing it to drain completely.
Yes, get a 30 to 20 amp puck adapter and plug it into your 110v outlets.
The trailer's converter will keep the battery charged.
I'm pretty sure your Palo doesn't have a factory disconnect switch.
They're easy to install.
Dan-Retired Firefighter/EMT
'07 Roo 23SS pushing an '07 Chevy Avalanche
Equalizer WDH and Prodigy BC
Old 06-16-2016, 02:10 PM   #18
2014 Solaire 147X
RamsFan1's Avatar
Originally Posted by 2ooler View Post
Hello everyone,
(tenting 30+yr).
Rick
Ours did not have a battery disconnect. I installed one and it helped, but there must be something that still draws, as it would still go dead, just took longer.
As Bikendan said, plug it in at home. My sits in storage since I am HOA, and I installed this. Works great.
Nature Power Solar Battery Charger Kit- 18 Watt - RDK Products 40158 - Solar Panels - Camping World
2011 Chevy Traverse
2014 Solaire 147X
Old 06-16-2016, 02:36 PM   #19
Thanks for the replies and links. I guess I'll have to watch it a little closer in the future. The disconnect sounds like the way to go.
Old 06-16-2016, 03:30 PM   #20
bikendan's Avatar
you should have the battery tested with a hydrometer.
you may have damaged it permanently.
batteries shouldn't be allowed to go below 50% charge level.
