Old 04-01-2015, 01:46 PM   #11
Jennifer9's Avatar
Thanks everyone. I believe where the vent is located on the outside corresponds to an area under the couch inside if I remember correctly, and there is an access door there as well.
I will check it tonight and see what I can find.
We used the camper in the fall and used the furnace the whole time as it was pretty cold that weekend. We didn't have any issues so I hope we dodged a bullet here and that our camper was manufactured properly.
2015 Solaire 163X
2015 Chevrolet Silverado 1500 High Country
2009 Chevrolet Tahoe LTZ
Jennifer9 is offline   Reply With Quote
Old 04-01-2015, 03:03 PM   #12
Factory Representative
Jennifer, thanks for the forum message, as for some background on this recall, there were very few units that left without a furnace vent. In fact up to this point, and we are 99% sure at this point, only 1 single unit that we produced left without a furnace vent, which is 1 too many, but in order to be safe we included many VIN numbers before and after this defective unit was produced. I looked at your picture and you do have a furnace vent, it's the metal vent to the right of the outside shower as the knowledgeable forum members have already pointed out to you. I am also not aware of any vents that were ever hooked up incorrectly. But for peace of mind, I would probably want to check that just like you are doing. Hope that helps a little
Have fun and make some great memories on your first trip
Any questions feel free to call us direct 1-800-297-5830 extension 4
Palomino Pal is offline   Reply With Quote
Old 04-01-2015, 03:09 PM   #13
Originally Posted by Kaadk View Post
On my Flagstaff it's under the dinette bench. Real easy to lift the bench and see if there's something between the unit and the outside vent. But that's just my trailer. I'd hate to try to do this if it was, say, under the fridge or something.
Mine is under the stove/oven in a compartment just tall and wide enough for the furnace. A real PITA to get to an remove which I did to rewire the blower. Also had to go thru another compartment to get the propane line disconnected.
Old 04-01-2015, 04:24 PM   #14
Kaadk's Avatar
Yep, that's what I would call a PITA.
Thankfully, from PP's post it seems this was a very isolated incident. I appreciate that despite there only being one incident, they're still checking a large range of trailers, just to be sure.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 04-12-2016, 09:04 PM   #15
Jennifer - hoping you see this. We just had the exact same repair done on my 2015 Vibe. There was no vent at all. The detector went off last fall and we brought it in and no one noticed. They sent it back saying it was okay. We turned the heat on and the detector went off. They figured out the problem today. It might be worth a recall for the Vibe also.
Lm2b is offline   Reply With Quote
forest river, palomino, recall
