Old 04-21-2015, 09:46 AM   #1
Microwave Issues
We have a 2005 Palomino Stampede 21SDSL. We pulled it out of storage and started checking everything. The microwave/convection oven won't heat up. It lights up and runs but doesn't get anything hot. Started tearing it apart so I can look into the issue but can't figure out how remove it. The microwave is held in by 2 screws from the side but the fan structure has a side panel that you can't remove. Also, the fan structure is held in by 4 bolts from the top but you can't access those because there is no access panel. Any help would be appreciated. Here is a picture showing everything.
2003 Chevrolet Trailblazer
jdits7 is offline   Reply With Quote
Old 04-21-2015, 01:47 PM   #2
Factory Representative
From what I recall about these, this is a Apollo convection oven, you may want to see if you can find any part numbers on it, but Apollo took care of all the servicing issues for it. I don't know if they still do or not, and I don't have any contact info for them anymore, but if you google Apollo rv convection oven you can find some troubleshooting tips
Palomino Pal is offline   Reply With Quote
Old 04-21-2015, 03:33 PM   #3
It is an Apollo, it is model number AAC24OTRB. As far as the microwave goes, I found out it might be just a fuse. But, I can't seem to figure out how to remove the unit to get to the fuse.
Old 04-27-2015, 06:23 AM   #4
Any suggestions on how to remove the whole unit out? Do I just open up the wooden area above the microwave? Just trying to figure this out before our first big trip on Memorial day weekend. Any help would be appreciated.
