Might be a longshot, but do you have an inlet for anti-freeze when winterizing? If the valve (which would be in a cabinet someplace close to the inlet) is set to winterize, the pump is trying to pull from there instead of from your water tank.
Plugged aerator screens are pretty common, but it that was the case, the toilet should still flush...
2022 Columbus 379MBC (Previous 2013 Rockwood Roo 23 IKSS)
2023 F-350 (Previous 2017 F250, 2005 F-150)
