Old 05-25-2016, 08:00 PM   #21
bpa098's Avatar
Opps where did that new battery come from
bpa098 is offline   Reply With Quote
Old 05-26-2016, 06:58 PM   #22
LBJester's Avatar
Looking good!
LBJester is offline   Reply With Quote
Old 05-27-2016, 05:48 PM   #23
bpa098's Avatar
To save time and money, spent a lot of both already, I just moved the light higher. Hole is covered and everything is sealed. Just in time cuz rain is coming
Old 05-27-2016, 06:04 PM   #24
rsdata's Avatar
Nice when a plan and a mod come together to a good conclusion...
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 05-28-2016, 03:37 AM   #25
bpa098's Avatar
Thanks. First real mod I've done. So many I'd like to do but too scared to screw something up. I'm handy to any extent. Better at fixing something than building new. The panel above my fridge is begging to be opened and made into storage, I'll get the courage to take a chance on it one day.
Old 05-28-2016, 07:08 AM   #26
B, I thought of adding a box similar to the one you have, but it would hit the bumper in a tight forward turn. So, I found this one, sits below the frame between the rails. And, doesn't interfere with the light. I did have to design and fabricate the mount, not to mention redoing the front mount after installing the Andersen hitch and adding two more 6 volt battereies. The two bottom photos is before the last redo. I also have added an electric tongue jack since then.
WW
ID:	109314   Click image for larger version
Name:	Box finished from left.jpg
ID:	109315   Click image for larger version
Name:	Box showing false bottom.jpg
Old 05-28-2016, 07:21 AM   #27
bpa098's Avatar
Nice job. I looked at boxes like that but wanted more space. I about Jack knifed the trailer one day to see if I had room and I should be fine. Haven't tested with it on yet. Next year I plan to add another battery and possibly solar
Old 05-28-2016, 08:04 AM   #28
Thanks; it is crowded in there. But also holds cords, EMS and a little more. When adding that much weight consider carefully the TW. I needed more and figured the pro outweighed the con. Rule of thumb: try to match battery total AH to solar panel watts. I have 460AH with 450w in panels. A 30A PWM controller works well. I can run the fridge on 120vac all day while traveling and not get below 80% battery capacity. Saved propane and is safer.
WW
Old 05-29-2016, 09:45 PM   #29
ROCAMPER's Avatar
WW
Did you get that in black or did you paint it?
ROCAMPER is offline   Reply With Quote
Old 05-30-2016, 05:25 AM   #30
bpa098's Avatar
I bought mine already black, most boxes come black or the aluminum chrome finish
storage
