Old 08-22-2013, 12:23 PM   #1
rycej's Avatar
Cadet 192T ... is there a water filtre?
I've been looking through the manuals that came with our 2014 Cadet 192T and saw one for a water filtre system. I haven't looked that hard just yet, but in my bit of poking around the trailer, I haven't come across a filtre anywhere.
I'm not sure if the package of material I got with the trailer is just a generic package for all Surveyors or not.
So does anyone know if the 2014 192T has a water filtre system in it, and if so, where is it?
Thanks, James.
2013 F150 v8 4x4 Supercab
2014 Surveyor 192T
rycej is offline   Reply With Quote
Old 09-23-2013, 11:41 AM   #2
Triguy's Avatar
I can't help with your specific trailer, but if there is a filter, the first place I would look is to follow the water line back from your water heater or follow the line up from the freshwater tank and/or city water connection.
My current trailer (different make) has the pump and filter hidden behind a false panel that you need to unscrew for access.
Good luck!
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 09-23-2013, 12:46 PM   #3
rycej's Avatar
Thank you. I will follow back some lines and see if I can find anything. Guess it doesn't hurt to pop off a few screws on a panel if I find them.
2014 Surveyor 192T
Old 09-23-2013, 12:51 PM   #4
wmtire's Avatar
Although I don't have your specific trailer, I might can offer some suggestions:
My water filter is behind a cabinet door underneath my television. You cannot just open this door either. You have to remove two screws that hold a hinge clasp on one side of the door......and it has two working hinges on the other side of the door.
Don't ask me why they have it designed this way. There is another door mounted exactly like this at the bottom of my pantry that I have to take the screws out to access the back of my water heater.
2011 Flagstaff 831 RLBSS
I’ve lost my scapegoat.
water
