Old 10-20-2013, 08:57 PM   #1
Floor repair photos
Started to repair a 4'x4' sect in the entrance area, water soaked
ID:	41472   Click image for larger version
ID:	41473   Click image for larger version
ID:	41474   Click image for larger version
ID:	41475   Click image for larger version
lunarcaptain is offline   Reply With Quote
Old 10-20-2013, 09:09 PM   #2
stevengb's Avatar
Scary but looks like you're doing a great job. What did you use to replace the Styrofoam sandwiched between?
Steve and Michele Bassett
2014 Surveyor Select SV305
2005 Ford F250 Lariat SuperCab 6.0 TurboDiesel
stevengb is offline   Reply With Quote
Old 10-21-2013, 06:31 AM   #3
pink styro foam insulation
Old 10-27-2013, 06:08 PM   #4
Heres the end result
ID:	41894   Click image for larger version
Old 10-27-2013, 10:15 PM   #5
stevengb's Avatar
Looks great! Bet you saved yourself a ton of money and you know it was done right!
Old 10-27-2013, 11:01 PM   #6
wilem's Avatar
Very nice job.... well done.
William
Master ASE
Private pilot SEL
A&P
jack of all trades master of one...LOL
http://imageshack.us/a/img32/3111/ypy.JPG
wilem is offline   Reply With Quote
Old 10-27-2013, 11:08 PM   #7
Retired on the weekends
The RB's Avatar
Fantastic ! Looks like you got it done. Do you know what caused the damage?
2008 Sunseeker 3120 DS
CLICK HERE FOR THE PACIFIC NORTHWEST RV GROUP
The RB is offline   Reply With Quote
Old 10-28-2013, 06:40 AM   #8
damage supposedly caused by an over flowed toilet, and further not winterizing and the water filter broke and the hot water heater froze and split.(filter repaired and hotwater heater replaced before i got it). the total cost of repair was less than 50 bucks. got cutoff pieces (some 2 x 4 pieces and a 4x4 sheet of press boardwas 3.50 total)from homedepots end cut drop cart, and the tile was .69 cents each(16 sf) the styro foam was the most expensive at 12 bucks(had to buy way more than i needed.
Old 10-28-2013, 06:41 AM   #9
there is a soft spot on the other end...but that getting left for now....maybe next fall i will delve into that one.
Old 10-28-2013, 07:15 AM   #10
Your lucky,local RV repair shop had a ROO with (Floor water damage). The walls and Floors are the same makeup. They had to separate the (outside walls and everything inside from the floor & frame. The outside walls sit on the floor,which was rotten from water damage. How did your floor damage (Stop) before going under the Walls,which support the walls? Youroo!!
