Old 05-12-2013, 12:38 PM   #1
Hybrid 233T's Avatar
Furnace Stop Working on My 2006 Surveyor
Hi All,
Woke up last night to some cold weather. Wife attempted to turn on the furnace and nothing! Is there a reset bottom or should I just take it in for service? I have 2006 SV 233T Surveyor by Forest River.
Hybrid 233T is offline   Reply With Quote
Old 05-12-2013, 12:58 PM   #2
Originally Posted by Hybrid 233T View Post
Hi All,
Check stove and see if it lights, if not, you may be out of propane. If stove lights, check fuse for furnace. Is it a manual light or DSI?
Old 05-12-2013, 01:27 PM   #3
Stove still lights so I don't think propane is the issue. There are no LED's on in the fuse lit up. To my understanding, when there is a lit LED it means the fuse is shot. Lastly, none of the circuit switches are marked furnace.
Any other suggestions? Thanks for the feed back.
Old 05-12-2013, 01:28 PM   #4
Oh, forgot to say that the furnace lights automatically.
Old 05-12-2013, 01:37 PM   #5
Does the fan start and then go off after a few seconds?
Old 05-12-2013, 02:11 PM   #6
Nothing!? Normally, the fan starts, then the auto ignitions lights, then we have heat. I wonder if the thermostat is bad?
Old 05-12-2013, 02:19 PM   #7
Check the fuse panel and inspect the fuse regardless of whether there is an LED lite or not.
Old 05-12-2013, 02:21 PM   #8
Will do! I'll let you know what happens.
Old 05-12-2013, 02:33 PM   #9
Herk7769's Avatar
Turn off the furnace at the thermostat and pull the fuse.
Wait several seconds ( a minute is better) and plug it back in.
Select heat and set thermostat so blower starts.
Check that blower runs.
If not it could be a bad thermostat; motor relay; high limit switch; motor; or control board.
Attached is the furnace trouble shooting guide.
Name:	Suburban Furnace 001.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
