Old 11-05-2014, 02:58 PM   #1
senior junior member
New Hampshire trip
After logging almost 5,000 miles we are back in Colorado. Had a great time and had no problems other then moisture under the mattresses. Still haven't been able to eliminate it.
rgates800003 is offline   Reply With Quote
Old 11-05-2014, 07:44 PM   #2
Rrickim63's Avatar
Other than leaving a bunk window open slightly, i get the same problem especially as the temperature drops. Using a space heater vs propane heater seems to lessen the dampness.
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is offline   Reply With Quote
Old 11-10-2014, 09:21 PM   #3
Canadian Member
itat's Avatar
The moisture under the mattress is caused by the temp differential between the inside of your Surveyor and the outdoor temp on the other side of the bed platform. Try something like Reflectix insulation under the mattress as a thermal break.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 11-10-2014, 10:20 PM   #4
bikendan's Avatar
Reflectix didn't work for us.
All that changed is the moisture forming on the Reflectix, instead of the bunk door.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 11-10-2014, 10:28 PM   #5
Canadian Member
itat's Avatar
New Hampshire trip
Bikendan, did you eventually find something that worked? At least the Reflectix wouldn't absorb any moisture. If the Reflectix got damp rather than the fabric of the mattress, that would be an improvement but obviously if you can prevent any condensation that would be preferred.
Old 11-10-2014, 10:51 PM   #6
Love the Kancamagus Highway, Mt. Washington, Sacco River,and Lake Winnipesaukee all in New Hampshire! Youroo!!
Old 11-11-2014, 02:17 AM   #7
bikendan's Avatar
The problem with condensation is that the mattress bottom absorbs it, not the Reflectix or the bunk door surface.
I also tried 1/4" foam insulation that had a silver foil side. Same result.
I finally tried an old wool blanket, which wasn't perfect but was better than the others.
Old 11-11-2014, 11:28 AM   #8
Try equalizing the temp between the inside of the coach and the storage area under the bed...
2010 Georgetown 300FWSSouth Florida
speedjester is offline   Reply With Quote
Old 11-11-2014, 12:10 PM   #9
bikendan's Avatar
Speedjester, This is the Hybrid TT section and hybrid beds don't have storage areas under them. They hang out in the air, like popup beds and are also covered by canvas. Therefore they are subject to outside temps more than a bed you're describing.
Old 11-11-2014, 12:20 PM   #10
New Hampshire trip
I apologize.. I wasn't aware... Is there a way of maybe putting something between the bed and the bunk to raise it a bit and allow for air circulation..maybe build a type of raised platform..maybe a piece of lattice cut to size raised by a few pieces of 1/2" stock..should break down easy and store in small area... Just a thought ..good luck..
