Old 05-17-2015, 08:18 PM   #1
No hot water.
Hey everybody. I have a 2015 forester surveyor. 191t. I'm have a problem with the hot water. I took it out for the first time this weekend. Filled the fresh water tank and turned on the valves under the seat. I let the hot water tap run to fill up the tank the. Switched the start button on for the gas to heat it up. The tank did light up. Saw the flame in back. We left for a bit and ce back turned on the tap and had hot water for about 30 seconds. Then nothing. I turned the gas switch off and tried the electric heater. Same thing. Hot water for about 30 seconds. Any ideas?
Sac3100 is offline   Reply With Quote
Old 05-17-2015, 08:32 PM   #2
Cyber Phrenologist
Radio's Avatar
The fact that you saw it light and it did heat SOME water indicates the heater is working. I'd look at the bypass valves. Sounds like hot and cold water are mixing. If you have an outside shower sometimes the valves on that are left open allowing hot and cold water to mix at that point, too.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 05-18-2015, 11:06 AM   #3
TURBS's Avatar
Agreed, by pass valves are turned incorrectly "behind wh" and or outside shower valves are on mixing hot and cold water.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "4 nights"
Old 05-18-2015, 03:39 PM   #4
Thanks guys. That was the problem. Much appreciated. Now I don't have to get a cold shower. Lol
Old 05-18-2015, 03:55 PM   #5
TURBS's Avatar
Unless you "need" one lol!
Glad you got it.
TURBS
2015 camping "6 nights"
Old 05-18-2015, 07:55 PM   #6
Cyber Phrenologist
Radio's Avatar
And it was a cheap fix.
KU4OJ
Old 05-27-2015, 06:50 PM   #7
Marines0811's Avatar
Yup a friend of mine had the same thing this weekend. Bypass value was opened
Marines0811 is offline   Reply With Quote
hot water, water
