04-11-2018, 07:38 PM
Nothing working in the surveyor 191T
Just bought this trailer and pulled it home and set it up in my driveway about 4 days ago. All the lights and everything was working until today and now the whole thing is dead. We've barely run anything, just given a few friends a tour. So we've had lights on for maybe half an hour in total for the last four days. Went out there just now...nada. Can a battery run down that fast and with that little use? And, if so, how do we charge it?
Any help appreciated.
Signed,
Confused in Kentucky
04-11-2018, 07:45 PM
Yes
There are several things that are always on ( parasitic draws) that don't draw much but enough to kill a battery in about a week. If you are going to store the new toy for more than a few days, you need to do one of the following.
1. Keep it plugged into shore power ( 110VAC)
2. Disconnect the battery by either removing the ground wire or have a disconnect switch added.
3. If you have 110VAC available you can add a battery tender or CTEK maintainer to keep the battery charged.
4. Add solar panel and controller if you have access to sun.
Number 2 is easy and quick, Number 3 and 4 are good longer term solutions.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-11-2018, 07:52 PM
Signed,
You don't want to allow your battery to discharge too much or you can ruin or shorten it's life.
Your RV has a built in converter, which is also a battery charger. For now, You just need to plug into 120 volt AC shore power to power the converter (and thus charge your battery). You may have an adapter that will allow you to plug your RV into a household outlet at home.
These links may help you understand:
Basic RV Electricity - RV Information (RV Maintenance)
RV Converters and Amp Draw - RV Information (RV Maintenance)
http://www.marxrv.com/12volt/12volt.htm
2011 Flagstaff 831 RLBSS
04-11-2018, 07:53 PM
Thank you so much for this quick feedback!
So, apparently, it's actually dangerous to drain the battery to zero. We had no idea about the less obvious drains and thought we had it buttoned down. One last not very smart question: how to you charge the thing back? I have one of those plug in chargers for cars that plugs in? Can we hook the paddles on that thing to the ports on the camper battery?
04-11-2018, 08:16 PM
do you have the simple common adaptor to change your 30 amp rv plug to a standard house hould plug? that is the easiest way to keep your battery charged while not using camper. Yes you can hook your charger to the battery terminals just make sure its a smart charger and don't over charge.
The responses from the site team were complete and spot on.
04-11-2018, 08:19 PM
Signed,
Sorry to hear you are having problems,
I would call the dealer and ask for a proper PDI so you know how everything works. Who was the dealer so we know to avoid them.
A PDI Is a Pre Delivery Inspection where they are suppose to show you how to work the systems in your trailer.
04-11-2018, 08:37 PM
The did give us a VERY quick demo. We bought it at mid-state RV near Macon, Georgia. While they mentioned disconnecting the battery if we were "going to store it", I took this to mean like storing over the winter. It didn't occur to me the thing would die inside of a week. But I now understand this is to be expected because of drains on the battery that aren't obvious.
06-10-2018, 06:01 AM
I would guess your battery was barely charged when you picked up your camper, you can run a heavy duty extension cord from your house or garage and use an adapter so it will plug into your regular extension cord.
Once you plug in your camper to the house, your built in charger will charge your battery and keep it charged.
Here is a link to one, sometimes Walmart has some in store.
https://www.amazon.com/Camco-PowerGr...cmL&ref=plSrch
2016 Shamrock 23WS
2018 F150 Ecoboost
06-10-2018, 06:19 AM
Originally Posted by wmtire
Too bad you can't make this a terms of use agreement before joining the Forum. It would be helpful for as to say "You may find your answer in the terms of use"
