Old 07-23-2012, 03:11 PM   #11
bikendan's Avatar
we use a BBQ lighter also.
we had lighting issues last week when camping.
had ran the stovetop burners long enough, we thought, to have got all the air in the propane lines out.
but, when we tried to light the pilot, it took a long time and we held the knob in for more than 40 seconds each time.
finally after 6 attempts, it finally lit and didn't have any more problems lighting it.
so, we need to let the pilot run longer, especially since this was the first lighting since last year.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-23-2012, 03:27 PM   #12
Thanks ya,ll. The misus is now a happy camper again. I will chalk this up to too many years of electric ranges. Right on the money, hold the dang button into light the pilot. Of yezh and the binder with all the distructions is 600 miles south at the house. Besides who really reads those things after all.
Thanks everyone for the help and humor.
2012 Coachman Freedom Express 19SQX Hybird
2008 Chevy Trailblazer SS
DaveB is offline   Reply With Quote
Old 07-23-2012, 04:40 PM   #13
Glad you got the oven lit! On ours, couldn't light the oven because the knob would hit the front panel before going in far enough. I found a tip on line to pull the knob off and put something in the hole so it wouldn't go on the post as far. stuck a little piece of toothpick in there and it has been working fine for 3 years.
akcampr is offline   Reply With Quote
Old 07-23-2012, 04:50 PM   #14
Timex's Avatar
This may start a new thread but turn the oven down 50 degrees to cook if you are used to an electric oven.
Timex is offline   Reply With Quote
Old 02-23-2016, 06:08 PM   #15
I can get the pilot light to light without any problem. My problem is getting it to remain lit after the oven heats to the set temp. Any ideas?
flamingo is offline   Reply With Quote
Old 02-23-2016, 08:24 PM   #16
Our oven did the same thing. Pilot would burn fine main burner would light and oven would come up to temp. Then main burner would go out. When thermostat called for heat again pilot would blow out. Found pilot burner assembly was bad. A bunch were made with wrong size orifice hole. Got a new one from suburban. All works fine now.
beachcamper is offline   Reply With Quote
Old 02-24-2016, 06:54 AM   #17
jeff64's Avatar
X2 on the symptom and fix
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 03-02-2016, 12:06 PM   #18
wicked1's Avatar
Have not used the oven in either of my trailers although GF said this year we will as we have some big trips planned with other campers and since we are Italian she plans on using it to warm food, let the Camping begin, Yum
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
