07-23-2012, 09:40 AM
Lighting the oven
Ok so here we are on our first trip. Things going great. UNTIL we want to make biscuts in the oven. How do you get the pilot to light? Burners work fine, but no gas to the oven pilot light. Am i missing a valve some where?
Its a coachman 19SQX with a suburban stove/oven.
2012 Coachman Freedom Express 19SQX Hybird
2008 Chevy Trailblazer SS
07-23-2012, 09:45 AM
Are you holding in on oven knob while lighting?
I just lit mine for the first time and it took about 2 minutes before pilot stayed lit after releasing knob.
Did you have knob in pilot light position?
Ron
07-23-2012, 09:51 AM
AKA Bluebird
Not sure about your stove but with many of them you have to turn the knob to "light" and hold it pushed in while lighting the pilot light with a long gas match. Keep the knob pushed in for maybe 20 seconds or so after it lights. Two people can do it more easily than one. A flashlight can be useful.
07-23-2012, 10:41 AM
It's real easy if you are a midget, with knee pads, a back brace, shaved forearms and head, a match at least a foot long, glow in the dark eyes and the patience of Job.
Nigel & Bev
Brit Driver & Canadian Naviguesser
We summer in Cowichan Valley BC Canada & winter in Monchique Portugal great camping in both!
2011 Rockwood Signature Ultra Lite 8280ws 2011 Dodge Ram 3500 4x4 Diesel 2000 Honda S2000
07-23-2012, 10:45 AM
AKA Bluebird
And you have to do it all while standing on your head and rubbing your belly with the toes of you left foot.
07-23-2012, 10:53 AM
Ron
Yes - be sure to hold the knob in for a period of time before releasing - check your manual for the time.
07-23-2012, 11:27 AM
I used my manual to lite the pilot light so I wouldn't burn my arm hair. Guess I should have read it before and wrote down the time to hold the button in first. crap!
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
07-23-2012, 11:35 AM
No problem - failure to hold the knob in for lighting the oven is probably one of the most commons errors people make when trying to light their oven.
Hope it works for you.
07-23-2012, 11:46 AM
It can take some practice to light the oven. As already mentioned you need to press and hold the knob in while lighting the pilot light. A flashlight can come in handy to make sure the lighter or match is in the right spot. Once I see a red bud I know it's lit but I still hold in the knob for about 30 seconds or more as needed. It not uncommon to have some trouble lighting the oven for the first use on each trip. Sometimes lighting a burner will help but I believe you had already did this.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
07-23-2012, 02:18 PM
I find a barbecue light with an LED light built in is very helpful in lighting the oven. Like the one in the attached picture
Barney
2020 Salem Cruise Lite 241QBXL
2016 Ram 1500 Big Horn Eco-Diesel
Previous Trailer -> 2012 Rockwood Roo 233s
-> 1996 Jayco 1207
07-23-2012, 03:11 PM
we use a BBQ lighter also.
we had lighting issues last week when camping.
had ran the stovetop burners long enough, we thought, to have got all the air in the propane lines out.
but, when we tried to light the pilot, it took a long time and we held the knob in for more than 40 seconds each time.
finally after 6 attempts, it finally lit and didn't have any more problems lighting it.
so, we need to let the pilot run longer, especially since this was the first lighting since last year.
07-23-2012, 03:27 PM
Thanks ya,ll. The misus is now a happy camper again. I will chalk this up to too many years of electric ranges. Right on the money, hold the dang button into light the pilot. Of yezh and the binder with all the distructions is 600 miles south at the house. Besides who really reads those things after all.
Thanks everyone for the help and humor.
07-23-2012, 04:40 PM
Glad you got the oven lit! On ours, couldn't light the oven because the knob would hit the front panel before going in far enough. I found a tip on line to pull the knob off and put something in the hole so it wouldn't go on the post as far. stuck a little piece of toothpick in there and it has been working fine for 3 years.
07-23-2012, 04:50 PM
This may start a new thread but turn the oven down 50 degrees to cook if you are used to an electric oven.
02-23-2016, 07:08 PM
I can get the pilot light to light without any problem. My problem is getting it to remain lit after the oven heats to the set temp. Any ideas?
02-23-2016, 09:24 PM
Our oven did the same thing. Pilot would burn fine main burner would light and oven would come up to temp. Then main burner would go out. When thermostat called for heat again pilot would blow out. Found pilot burner assembly was bad. A bunch were made with wrong size orifice hole. Got a new one from suburban. All works fine now.
02-24-2016, 07:54 AM
X2 on the symptom and fix
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
03-02-2016, 01:06 PM
Have not used the oven in either of my trailers although GF said this year we will as we have some big trips planned with other campers and since we are Italian she plans on using it to warm food, let the Camping begin, Yum
2014 F150 FX4 Crew 4X4 EB
2015 Roo 23IKSS
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
