Old 04-23-2012, 06:29 PM   #1
daltonfreedom's Avatar
12 volt power issue
We have a 2012 XLR 29MBV Viper Toy Hauler. When we un-plug the shore line we do not have 12 volt power. Talked to Diane at Forest River sales / warranty dept. and she said it was the "breaker switch" at the front of the trailer on the frame, I looked under the trailer and there was a pannel with 4-5 switches not sure what one it is. anyone ever have this issue? any help would be great. Thanks!
daltonfreedom is offline   Reply With Quote
Old 04-23-2012, 06:50 PM   #2
TURBS's Avatar
could you take a pic ?
Old 04-23-2012, 07:11 PM   #3
Take the cover off the battery box. Trace the positive, lead and see where it goes. I've never seen 4 or 5 switches under the tongue of a trailer, but haven't seen an XLR yet. There are usually at most 3, one for 12 power, one for slides, and one for landing gear on a fifth wheel. Can't imagine 4 or 5. Also never seen them mounted in a panel, and never seen anything I would call a switch. Just a circuit breaker with 2 lugs, large wires on each end, and a reset button that you can never find. Of course I try not to claim to have seen it all.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 04-23-2012, 07:20 PM   #4
Looks like behind every connector pole is a fuse/breaker but not sure which is bad, how do you tell which bad
Old 04-23-2012, 07:22 PM   #5
TURBS's Avatar
get your multi meter out and test both side of relays .
IF you don't have one then invest in one . With a camper you will need one !
Old 04-23-2012, 10:24 PM   #6
Looking at the picture, the top right is the wire coming from your battery. That feeds the buss bar, that makes everything hot. The one that would go to the converter, to provide the trailer with 12 volts is the bottom left one, I think. It will be a large wire, 8 gauge or so, about the same size as the top right one, which I am pretty sure comes from the battery. I do see what I think is another large wire on the bottom right, hard to tell from the picture. It might just be part of the wire from the bottom left post, and the other bundle has it hid. You could try resetting them all, doesn't hurt anything. Small usually black button, on one end. May have to push it with a toothpick.
LadyWindrider
Old 06-08-2012, 01:09 PM   #7
First, want to say Thank You to everyone helping us with our 12 volt issue on our 2012 XLR Viper. We did finally resolve the issue, turns out there was a switch behind the battery.
Old 06-08-2012, 02:10 PM   #8
TURBS's Avatar
Lol nice!
12 volt
