Old 04-06-2015, 07:55 PM   #11
WolfWhistle's Avatar
Nice pics PH! Glad you had a good thanksgiving. Family came over... my job is to eat all the left overs and there are a lot of them!
Thanks for posting. 4 - 12volt in the hand is better than 4 6 volters in the bush.
Thank goodness the wife loves it, nice job PH! 100 gallons in a day and a half! Your job if you choose to accept it (ha) is to take a water management class
If battery storage works like water usage, you will have to add more roof to handle the panels . I thought 200W would do it for me, but maybe 300W.
Inverters get pricey, but I would figure out how to run the 'things' that can tolerate it on square wave and the picky things on true or pure sine wave. First you have to get a handle on how much DC you are going to need. Get a good inverter or inverters when you do. I would like at least 2000W inverter. I'm not the solar expert, but my thoughts would be to have a true sine wave and a square wave inverter, if that is feasible.
I have added reflectix under the floor under the garage. I could tell a slight difference, but no hard data to prove anything. It still will need 2 to 3 times more heating BTUs. If you consistently camp at low 40s, I would add a Wave8 in the garage and another one in the "kitchen".
Sound insulation around the genny. Suggest using the high dollar HushMat; maybe look into sitting on thicker/betterr rubber mounts and muffulate the heck out of it.
We must have different sinks, mine is a 40 / 60 split with two bowls.
I would like another tele, as well.
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 04-06-2015, 07:56 PM   #12
Very nice th Play Harder! What is the stats or info of your tv if I may ask?
hdmtnrider is offline   Reply With Quote
Old 04-06-2015, 08:12 PM   #13
Looks good! After your long trip to get it, I bet it felt good to be out with the family camping in it
gtsum2 is offline   Reply With Quote
Old 04-06-2015, 09:47 PM   #14
Play Harder's Avatar
WW
I've tried water management grrrrrrr -- it normally take a tank for my wife to get it it was only 54 gal in a day and a half lol....
I'll be putting in a 3000 inverter - I only use for directtv and TV, lighting, charging IPads, iPhone ect..hope, been fine with 4 12v for the last few years might have 2 TV on at once would be only difference.
I'm claiming warranty over the furnace and floor insulation due to fact that I paid for the extreme weather package and it was special ordered to have the Extreme weather package added which states "radiant Roof / Floor / slide out Floor / Front insulation (R-38 @ 80f)" I paid for and ordered extreme package and expect the floor to be insulated to R-38 as stated. Also FR ligature states it comes with a 20000 btu furnace mine came w a 19000btu input value and is only rated output is only rated at 14440 btu with 2 vents hooked up not 4 - with 4 it's output is more like 10000 btu - this is why it can't heat the TH now you might think I'm being a stickler over furnace but if you put it in you specs as a 20000btu furnace you better put a 20000btu furnace in.
Hopefully theses are simply warranty issues - and just an oversight on FR part
Other that those 2 ongoing issues can't wait to add my own modifications- my RV season has started and plan to enjoy my new TH as much as possible and often
Get out and Play Harder😛
2016 XLR Hyper Lite 29hsf - loaded picked up 3-24-2015😊
2008 Can Am Spyder
Kite Boarding is my Addiction - GOT WIND!
Play Harder is offline   Reply With Quote
Old 04-06-2015, 09:51 PM   #15
HDmntrider
It's a chev quadrasteer 6.0 gas 1/2 ton HD w air bags and adjustable rancho shocks, E ply tires - almost 300,000 miles on her
2008 Can Am Spyder
Old 04-07-2015, 11:04 AM   #16
northstar1960's Avatar
PH , harbor freight carry's inveters 2000 watt for 129 , 3000watt for 299 and 5000 watter for 399. plus they have 20% off coupons. 54 gallons in a day and a half is a lot of water . in my slide in i had 36 gallons and it could last me 2 weeks . but no wife and that's the difference . According to WW there are 2 tanks for the grey water one could be made an extra fresh water storage and give you another 28.5 . we really don't need 57 gal grey water tanks . I'll be picking mine up tomorrow and if it's not a 20,000 btu furnace then I'll not sign off on the unit .like you said it's what is stated in the specs .looks like I'm getting the 2000 watt inverter . they also sale 2/0 battery cables 6' x 2 for battery hook up and inverters for 39.99 .
i'll be posting my findings tomorrow eve after chacking out my unit
northstar1960 is offline   Reply With Quote
Old 04-07-2015, 11:25 AM   #17
Take the metal cover off the furnace 2 screws and the label is there looks like this //
Name:	ImageUploadedByForest River Forums1428423585.698756.jpg
Also check the walk thru dinette couches - they have 4 legs on them to support when in use as bed - all 4 should ouch the ground when in bench. In full down position - some how I only got 2 adjustable legs and 2 legs that are not so those 2 are too short..
I sent a message to BB on my warranty concerns and haven't heard anything - just filed my concerns with RVW yesterday-
guess we will get to review how both handle a warranty issue soon.
Old 04-07-2015, 11:56 AM   #18
Play Harder & Northstar,
I will be following your post/warranty work very closely. Just for some additional info. Check out the furnace suppliers web site for their ratings -
Airxcel | Suburban Manufacturing Products
They seem to match the label on the furnace but not the FF literature.
Wishing you the best...
2015 XLR Hyperlite 29HFS (installing mods...)
2018 Chevy 3500HD 4X4 6.0L
stevejd235 is offline   Reply With Quote
Old 04-07-2015, 12:06 PM   #19
As for using what you have battery wise and stacking several of them, I've always been told that to do that the batteries should be identical in weight, size and age. Is that not true?
breezyhillfarm is offline   Reply With Quote
Old 04-07-2015, 02:30 PM   #20
Breezy
Yes that is true for optimum operation and life of the batteries- often if one is bad it normally will take out the one next to it. And also even when you buy the same batteries take a volt meter w you and try to find 4 that are putting out the same voltage - try to get 4 matched ones - I work with batteries a lot - on portable x-ray machines which have 30 plus --
You should have at least your pairs matching voltage when fully charged - you will be surprised at the different Voltages you will get on a batch of batteries.
You'll get longer life out of your batteries if you match but it's not gonna hurt anything if there not 100% match just shorter life span
